September 23, 2026, 04:03:24 am
| |-+  For sale!
| | |-+  2332 type 1 engine SOLD
Author Topic: 2332 type 1 engine SOLD  (Read 2472 times)
Leif Nyström
« on: October 21, 2010, 21:02:26 pm »
Alu. high roof engine case, center shuffle pin, 94
bore, full flow etc. 10mm inserts
84mm crank, wedgemated, typ 1 main
chevy rod journal std.
200mm chromoly flywheel 8-stift,
wedgemated.
Scat H-beam rods, 5.7" chevy, 3/8" bolts
Crank gear assy. kit racer spacer
Stage 2 clutch, JayCee 4-puck disc
WEB 86C cam and lifters
Jaycee 3/8" chromoly push rods
Jaycee push rod tubes
CB straight cut cam gears
30mm Schadeck oil pump and fullflow cover
Tall Century 94mm cylinders, Cima/Mahle
94mm pistons
Street Eliminator cylinder heads, 94 bore, 44x37
valves, Erco triple springs, chromoly
retainers
10mm chromoly head studs
Scat  forged 1.25 rocker assembly
CB thinline 1.5 quart oilsump
Dual Italian Weber 44 IDF with street
elim. manifolds, linkage, stacks o filter
Bosch 009 dizzy, HD coil
36 hp style shroud, cylinder tin
12v alternator, oil filler, valvecovers with vents, etc etc.
Most parts are good used, some are new - pistons and manifolds...
Pretty much a turn key engine in parts 4000 euro, or put together as agreed..
« Last Edit: February 04, 2011, 08:37:25 am by Leif Nyström » Logged
