September 23, 2026, 04:03:23 am
| |-+  For sale!
| | |-+  NOS type3 parts - garage clear out
Author Topic: NOS type3 parts - garage clear out  (Read 2445 times)
Mario/DKT
« on: October 22, 2010, 07:12:52 am »
New project's need's space and money!
All is NOS and most is NIB
2 door handles Nr. 311 831 205 A left 90€
1 door handle Nr. 311 831 206 A right 90€
2 taillight bulb holder 69up 311 945 231 50€/pair
4 brakecylinder pistons, Nr. 311 611 657 E 10€/piece
2 chokes 6V right 311 129 192 F 10€/piece
1 indicator lens amber right(?) 69 up HELLA 15€
1 indicator rubber 64-69  35€/Stόck
10 vent wing fastener 61-67  8 left ones, 2 right ones 15€/piece
1 piston rod, Nr. 311 105 411 15€
1 lock for front hood 311 823 509 C  15€  1 pin carrier 15€
6 set's brake pads, Nr. 311 698 113A in box 20€/set
1 set brake pad's Nr. 311 698 095 20€
1 set brake pad's Nr. 311 698 115 20€
2 seals for Eberspδcher front, Nr. 311 291 727 5€/piece
2 seals for heat exchanger's, Nr. 311 261 731 5€/piece
2 brake drums rear 61-63, Nr. 311 501 615, 299€/pair obo
2 brake drums front, 61-63, Nr. 311 405 615, 349€/pair obo
2 drum brake spindles, Nr. 311 405 312 A 49€/piece
2 drum brake spindles, Nr. 311 405 311 E 49€/piece
1 disc brake spindle, Nr. 311 405 311 C 5 49€
1 lower torsion arm right 49€
1 filler cap with gasket 15€
1 drive shaft, Nr. 311 501 201 A  40€
2 brake cylinder ATE right Nr. 311 611 062 C 35€/piece
1 brake cylinder rear ATE Nr. 311 611 062  35€
1 Relais Nr. 311 941 583 15,-€
2 squareback oder fastback rear fender's l+r NOS 275€/piece or 500€/pair
I have a lot more stuff (door's, bonnets, rims... NOS and used)! Will follow.
+ shipping or free delivery to volksworld show 2011
