September 24, 2026, 08:09:06 am
| | |-+  Kenndy 2300lb Early Green Pressure Plate W/3 Supports
Author Topic: Kenndy 2300lb Early Green Pressure Plate W/3 Supports  (Read 3261 times)
« on: October 25, 2010, 01:12:51 am »
What is so good about these pressure plate compaired to the new ones now??
Ted
kingsburgphil
« Reply #1 on: October 25, 2010, 02:55:04 am »
Ted
If you're referring to what was marketed as a Kennedy "Maximum", 35 years ago it was the best thing going.
Similar to Borg & Beck 3 lever design it used a diaphragm instead of coil springs. It was easier to modulate
than a full diaphragm clutch, but at a cost of higher pedal effort. Although stories of fractured pressure plates
circulated, we generally used the 1700 lbs. or the Maximum @ 2100 lbs. plus with a fibre disk. That is until the
three puck disc showed up and tranny builders learned to smile like Cheshire cats.  Grin
Or at least that's how I remember it  Wink
