August 13, 2026, 06:35:21 am
| | |-+  jumping spark
Author Topic: jumping spark  (Read 5471 times)
« on: November 07, 2010, 14:39:34 pm »
here is what a guy has on his engine.
the engine is a 2276 with a 130 cam and CB injection kit (computer and trottlebodies), the ignition is handled by a 009 with compufire and a MSD coil ( or similar)
the problem is that on his 3 and 4 cylinderside the spark jumps from number 4 to number 3 when it is being revved (static, no load). the other side is fine. i want to hear your opinions about it regarding what may cause this problem. thanks in advance.
Rasser
« Reply #1 on: November 07, 2010, 15:35:52 pm »
Faulty sparkplug cables/connector ends seems to be the obvious, have you tried to change them?
1955 type1
1966 type2 13w deluxe
« Reply #2 on: November 07, 2010, 15:55:31 pm »
thanks! no, but we will do that.  but would  it cause the spark to jump out of the barrel into the other?
Dougy Dee
« Reply #3 on: November 07, 2010, 21:31:17 pm »
Resistor plugs? Had similiar witj 12mm NGK plugs that were specified wrong to me. Went to non resistor plug and problem gone.
jamiep_jamiep
« Reply #4 on: November 08, 2010, 08:35:03 am »
I had a similar problem when the lead wasn't fully 'home' on the plug (even though it felt like it wouldn't budge any further on!).
jr59
« Reply #5 on: November 08, 2010, 09:57:21 am »
Also look closely to the  coil wires if they 're really next the injector ones you can have problem  due to "electric noise" .
you may run no longer than 10/13" long HT coil wire .We had the problem on the first CB turbo injection engine we built (And we take a lot of time to find the problem)
If you really don't find the pb don't hesitate to contact CB they re always there to help you!!  ((PAt down or mark lawless are very patient and ready to help even with overseas customer!! Cheesy Wink)
cheer
 JR
« Reply #6 on: November 08, 2010, 21:10:30 pm »
thanks again.
i will try to help him out with the given advice and have a good look at his wires.
and if i knew what he really has from CB i would have sent them an email, but i have to look at it and maybe it is better he does it himself.
