September 22, 2026, 23:29:37 pm
| | |-+  Looking for a QUIET electric fuel pump.
Author Topic: Looking for a QUIET electric fuel pump.  (Read 10594 times)
« on: November 09, 2010, 23:27:57 pm »
Looking for something quiet and can screw AN fittings into.
« Reply #1 on: November 09, 2010, 23:44:36 pm »
I got a rotary from CB and it is very quiet.  I think it's a Carter.  I had a Holley red and it drove me crazy with the noise and vibration.
Here's the link: http://www.cbperformance.com/catalog.asp?ProductID=577
« Reply #2 on: November 10, 2010, 00:20:45 am »
that's THE quiet pump. but you need to improvise to fit AN fittings.
i had the same issue and ended up with a Facet red top which is a lot more quiet than my previous Holley Blue.
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #3 on: November 10, 2010, 00:37:25 am »
   I run this.  It is very quiet. Pretty too.    Rick Sadler runs one too on the yellow car.
« Reply #4 on: November 10, 2010, 01:39:03 am »
Cool, Thanks for posting the pictures and the info. I havent driven a vw in some time daily , I remember the blue holly in the ghia, It got old quick !
« Reply #5 on: November 10, 2010, 02:35:01 am »
DG,
I run a Holley blue in my '69 for the last 10 years ... sucked until I rubber mounted it.
Turn the key and you can just barely hear it, but certainly not while the motor's running.
RUBBER MOUNTING makes all the difference. I'd explain how I went about it, but you're pretty good coming up with alternative implementations.
Here's looking up your old address ...
« Last Edit: November 10, 2010, 19:38:49 pm by TexasTom » Logged
Gavin - DVKK
« Reply #6 on: November 10, 2010, 06:46:08 am »
Carter electric. Silent and very reliable. I think I just had to run some adapter fittings to run my AN line to it and has never let me down, unlike my loud pos Holley...
« Last Edit: November 10, 2010, 06:48:56 am by Gavin - DVKK » Logged
deano
« Reply #7 on: November 10, 2010, 17:55:35 pm »
Gavin, which model Carter pump did you use?
Anglia Obsolete Guru
'67 Heaven
Kaferdog
« Reply #8 on: November 10, 2010, 18:19:51 pm »
Yeah it looks like the CB is a carter......
http://www.carterfueldelivery.com/fuelpumps/universal_fp.php
« Reply #9 on: November 10, 2010, 18:39:06 pm »
I use a pump from Mitsuba, no sound at all.
« Reply #10 on: November 10, 2010, 19:31:04 pm »
Red Holley mounted on Mercedes W124 air cleaner mounts... can't hear it inside or outside the car. I have AN-6 fittings on it.
« Reply #11 on: November 10, 2010, 20:28:26 pm »
jim, i'm quite curious as to how you mounted the holley. i tried the same with my blue pump, but it was too big, i sourced the exact same mounts. now i used them again with the facet pump that produces a quiet hum that let's me know it's on but in no way it's annoying.
Kaferdog
« Reply #12 on: November 10, 2010, 21:59:29 pm »
I was thinking about trying these...Huh
http://www.summitracing.com/parts/MAA-29069/?image=large
lofty1971
« Reply #13 on: November 10, 2010, 22:01:45 pm »
Soon as I start my 2276 IDA motor and go for a drive in my solid mounted 67, the red Holley is the least of my worries.....
I've learnt to welcome the nosie - all of it  Grin
« Reply #14 on: November 10, 2010, 22:20:15 pm »
Look under rubber bumpers in the mc master company catalog
Kaferdog
« Reply #15 on: November 10, 2010, 22:35:16 pm »
Yeah know Danny.... I keep forgetting about Mc Master-Carr...!! never thought to look there and they are just minutes away from me !
« Reply #16 on: November 10, 2010, 23:35:15 pm »
Ya, My mc master carr catalog, Is more wore out than my street rodder mags. The first thing I grab when I makeing something. You must be in sante fe springs? I made alot of stuff for there shippng dept.
« Reply #17 on: November 10, 2010, 23:42:47 pm »
those look identical to the mercedes mounts.
rick m
« Reply #18 on: November 15, 2010, 01:12:20 am »
Jason,
Does the Holley 125 have a built in regulator or do you run and external one?  I am considering a new pump as well on my new 2275 motor set up.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
Jason Foster
« Reply #19 on: November 15, 2010, 16:48:55 pm »
  It needs a regulator Rick.  The pump is constant at 7 psi.   I use a holley 1 to 4 lb regulator.
rick m
« Reply #20 on: November 16, 2010, 06:45:59 am »
Jason,
Thanks for the heads up.  I will be updating my pump soon.  Worked OK for the smaller webers but need more for the IDAs.
RM
Rick Mortensen
