September 22, 2026, 12:38:21 pm
| | |-+  what is a 'reasonable' deck height
Author Topic: what is a 'reasonable' deck height  (Read 5675 times)
« on: November 13, 2010, 15:26:10 pm »
i want to know what is a good or accepted as reasonable deck height in an engine?
my engine spec is 82x94. heads are 58cc and have a step in them. and without shims i have a deckheight of 0.52mm now. so with a shim tha measures 1mm (or a 0.040) i would end up with my desired CR of 9 to 9.4
is this OK or do i need more? can i get away with less?
« Reply #1 on: November 13, 2010, 17:09:30 pm »
with good parts 0.040 should be OK,
thats what i wanted to do when i still wanted to keep my engine NA
Jo Clifford
« Reply #2 on: November 13, 2010, 18:10:41 pm »
Yes,that is ok Smiley
Jo
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
« Reply #3 on: November 14, 2010, 18:35:07 pm »
Jo
thanks honeys  Wink
« Reply #4 on: November 15, 2010, 20:35:10 pm »
Rule of thumb is minimum 1mm but max 1.5mm to get enough squish.
How much is the step? You should add that to to your deck height.
« Reply #5 on: November 16, 2010, 11:39:01 am »
not sure if i can add the step to my deckheight. i don't want the piston hitting the step or so. i prefer to keep my pistons IN the cylinders for now.  Wink but i do understand what you are saying.
