September 25, 2026, 22:04:57 pm
| | |-+  my 54 oval bug
Author Topic: my 54 oval bug  (Read 7767 times)
vintagewagenwerks
« on: November 20, 2010, 14:48:03 pm »
Here some pics of my 54 oval project build two years ago.
Specifications of the engine:
-2007 cc
-78.4 Oettinger crank
-90.5 pistons bore
-AS41 VW case füll flpw modified
-30mm Oilpump
-1.5l add on oil sump
-EQ Powerpulley
-48 Weber idf carburators
-street eliminator heads 42/37
-camshaft unknow
It´s better to burn out than to fade away.
vintagewagenwerks
« Reply #1 on: November 20, 2010, 14:49:56 pm »
shit can someone tell me how to insert a pic i don´t know anything about bccodes
« Last Edit: November 20, 2010, 15:12:42 pm by vintagewagenwerks » Logged
papapsi
« Reply #2 on: November 20, 2010, 21:37:05 pm »
need to see pictures.  Grin
http://cal-look.no/lounge/index.php/topic,3632.0.html
vintagewagenwerks
« Reply #3 on: November 20, 2010, 22:08:40 pm »
ok maybe yet [ Attachment: You are not allowed to view attachments ]
« Last Edit: November 20, 2010, 22:12:04 pm by vintagewagenwerks » Logged
vintagewagenwerks
« Reply #4 on: November 20, 2010, 22:13:30 pm »
ok it works
vintagewagenwerks
« Reply #5 on: November 20, 2010, 22:20:19 pm »
some more
Wünderwolff
aka Dr. Jeckill
« Reply #6 on: November 21, 2010, 08:13:56 am »
I'm sorry to be the one to tell you, but this car does break some of the 10 commandments as described in the bible (old and new testament)  Wink
I wouldn't want to put it in a category, but lucky for me you already did in signwriting. It's a combination of vin+age and hoodride! Take my advice and start by putting it a slight bit higher at the back, keep the empi 8 (odd on an oval, but was done before with a lot of succes). Definitely loose the aerial (if not at least the rat fink on top), the sun visor and the eyebrows on the headlights. I know you like Jussi's car so keep the engine as it is: wild and unclean  Grin
You'll be one step closer to cal- look!
« Last Edit: November 21, 2010, 08:17:23 am by Wünderwolff » Logged
Wünderwaffe are Go!
vintagewagenwerks
« Reply #7 on: November 21, 2010, 13:24:38 pm »
Your opinion is right of course.Many styles combinated into one ,but there is something about the most people don´t know. This car was build as a memory of sad an glory moments in my live .It´s  a memeory for my lost friends and my family and should be a rememberance for my lovely wife when the day come i will die before her.A bug was always the center of my live.
I don´t go with the styles around me ,i create it like I love it Cheesy.
Jussis car is also very wonderfull to me ,because it is radikal wild and easy and nothing copares to it.
« Last Edit: November 21, 2010, 13:50:16 pm by vintagewagenwerks » Logged
