June 10, 2026, 01:40:20 am
Latest Member: mvptkfjb
| | |-+  Another 67-built
Pages: [1] 2 3 4 Print
Author Topic: Another 67-built  (Read 82134 times)
Wunder Wim
« on: November 21, 2010, 09:40:57 am »
Hello everyone,
just wanted to share some pictures of the new project I started.
The story behind the car is way to long but anyway: I started the work on this 67 about ten years ago. It was to be a present from my dad to my mom, but a lot of things happened lately, so I got the car.
Now about the car itself: body was partly sandblasted and welded up as factory specs, the floorpan and all the bolt on parts were also sandblasted and painted. Every bolt, nut and washer was sandblasted and cadnium plated or seomething like that.
But now I'll the pictures speak for themselves:
Here some  pictures of the parts that came with he car:
I know some of you won't consider it to be a Cal Looker because of the chroom trim, but I'm keeping it. It will be some kind of DKP III -style car.
Regards Wim.
« Last Edit: November 21, 2010, 09:52:50 am by Wim » Logged
Wünderwolff
aka Dr. Jeckill
« Reply #1 on: November 21, 2010, 10:08:56 am »
No posting! Keep building!
Wünderwaffe are Go!
« Reply #2 on: November 21, 2010, 19:40:30 pm »
I know some of you won't consider it to be a Cal Looker because of the chrome trim, but I'm keeping it. It will be some kind of DKP III -style car.
Wim, first off... beautiful looking car. Second, worry not what people say/think about retaining the factory trim and what's Cal Look or not. Third, you've already answered your post in the above sentence. 'Cause D.K.P. accepts Cal Look cars only. Have fun building your Cal Looker and we're looking forward to seeing more updated pictures of it.
Felix/DFL
« Reply #3 on: November 21, 2010, 19:48:05 pm »
Your dad has a great taste!
Red interieurs always look good.  Grin
Have fun!
Best greetings,
Felix
Kaferdog
« Reply #4 on: November 21, 2010, 19:52:08 pm »
Wim .....like Mark says "Don't worry what people say or think of your car " it's Your car ...! not anyone Else's !...it looks like you have a great start. I like the seat's they will look good with your color......What plans do you have for the motor...?...Good Luck !
Wunder Wim
« Reply #5 on: November 21, 2010, 20:21:00 pm »
Have fun!
Best greetings,
Felix
Hi Felix,
don't want to go in this subject to much, but just wanted to say that my dad 'had' a good taste. He past away way to early, so this ride will be some kind of tribute to him.
Greets
Wim
Wunder Wim
« Reply #6 on: November 21, 2010, 20:23:19 pm »
The plans for the motor: something around 2100cc, fuel injected and most of all driveble for the street. I plan to use it as much as I can...
mychatype3
« Reply #7 on: November 21, 2010, 21:03:36 pm »
Nice one Wim, cool bug with a great history, TOP.
(your bus is looking good also on the vct2-site)
Greetings mycha
1968 fastback "in resto"
« Reply #8 on: November 21, 2010, 21:52:57 pm »
Looks that this will be a cool ride,keep us updated and let the pics come.
wolfswest
« Reply #9 on: November 21, 2010, 22:02:54 pm »
Nice one Wim, hope to see it soon ripping up some tarmac at ter linden!  Grin
Wunder Wim
« Reply #10 on: December 21, 2010, 16:33:00 pm »
Just time for a little update:
The stock parts of the electrics are almost done. Everything is connected and instead of putting in a new loom, I decided to give it a littel bit of a clean up. Guess it came out ok.
And this is how it all looks under the hood.
One door is allmost done, just waiting for some parts to replace the rubbers of the quaterlights.
And just one shot from under the fuelcell. Some parts will be changed or added (dual master cilinder and a line-lock).
Thursday will be a fine day as I'm expecting some parts to be delivered but I'll keep you updated
thehanz DVK
« Reply #11 on: December 21, 2010, 19:50:51 pm »
nice car nice color and good plans, i see al lot off similarity's with mine, succes with the build and keep us posted...
« Reply #12 on: December 21, 2010, 21:05:26 pm »
Clean  Cool good work !
Wout
« Reply #13 on: December 24, 2010, 09:49:45 am »
Nice!!!
gr
Wout
Aircooled vw's for life!
Wunder Wim
« Reply #14 on: January 05, 2011, 20:52:10 pm »
Time for an update:
most of the parts for the interior have arrived so I got started with it. Still a lot to do but here's a preview...
The front of the car is almost finished: wings are bolted on using stainless steel bolts and washers, wingbeading is mounted as are the indicatorss with clear Hella lenses.
Next on is the rearend with all red lenses (just prefer the one color look)
Greetz
Wim
rick m
« Reply #15 on: January 06, 2011, 07:38:46 am »
Your car is looking very nice. What will you run for wheels, motor, etc.?
Rick M
Rick Mortensen
Driving Hot VWs since 1970
Wünderwolff
aka Dr. Jeckill
« Reply #16 on: January 06, 2011, 07:44:46 am »
Very nice Wimme! Make sure you can drive it by this evening for the monthly Cal-Look dinner.
Wünderwaffe are Go!
Wunder Wim
« Reply #17 on: January 29, 2011, 16:38:42 pm »
More parts have arrived:
The engine will be based around this machined case:
Engine will be something like this:
94 forged mahles
78 or 78.4 crank
44 / 37.5 heads with copper head gaskets
9.5/1 compression ratio
FK 7 cam with straight cut timing gear
1.4 rockers
H connection rods
lightened Cro mo flywheel
Sidewinder exhaust 1 5/8 inch
full flow with external filter and cooler with fan
CB Quick tune FI
MSD ignition
Gearbox:
Stock with supper diff, heavy duty clutch shaft, heavy duty side plates
Things to do to the chassis, install all this:
Koni shocks all around
koni steering damper
narrowed front beam
cb dropped spindles
cb disk brakes front and rear Porsche bolt pattern
large bore master cilinder
hurts line lock
gear box mount
rhino gearbox mounts
torque bar
heavy duty engine mount
But I'll keep you updated...
« Reply #18 on: January 29, 2011, 18:05:58 pm »
sounds good!
but are you sure the FK-7 isn't a typo?
lowfastbus
WUNDERWAFFE
« Reply #19 on: January 29, 2011, 18:13:43 pm »
Nice name change  Grin
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
Wunder Wim
« Reply #20 on: January 29, 2011, 18:28:08 pm »
sounds good!
Nope
FK-7 it is
288° duration
0.357 lift at cam, gives around 12.7mm lift with 1.4s
Sander/DVK
« Reply #21 on: January 30, 2011, 10:00:15 am »
Hi Wim, I think it looks 'Wunderbar' Wink Keep on the good work.
JeePee/DVK
« Reply #22 on: January 30, 2011, 10:26:48 am »
+1 Cool
« Reply #23 on: January 30, 2011, 11:24:20 am »
just a thought, but why not opt for a smaller inlet valve with the fk7? if not mistaken i think you are after torque and a smaller fastfollowing inlet just will fit this idea better IMHO...
otherwise this car looks really nice. the Wunderyearclub is coming out with some nice machinery it seems...
Wunder Wim
« Reply #24 on: April 20, 2011, 19:59:21 pm »
Just wanted to share some more pictures/ Not a lot of updates on the car.
Today I pushed her out of the garage so she could bathe in the sun. The color comes out lovely I think.
Now the garage is empty as the car is brought away to fit the headliner.
In this picture you can see the Cosmic cruiser pedal (which was bought here at the lounge) that was a bitch to get right but the result makes it worthwhile...
Tomorrow is going to be a very nice day, the new wheels are coming in. But tomorrow more about this...
« Last Edit: April 20, 2011, 20:04:43 pm by Wünder Wim » Logged
« Reply #25 on: April 20, 2011, 20:27:18 pm »
Awesome "Sleeper" Wim ! Keep us (me) updated about the CB Quicktune EFI !
Wunder Wim
« Reply #26 on: April 22, 2011, 09:22:02 am »
Hi Harry,
thanks for the support.
CB Quick tune is about to arrive in April, but it won't be for EBI to get it installed (have to build the engine first). But I'll keep you updated. Hope to get the engine (2165), gearbox and EFI installed by DDD.
If I make EBI, it will be with a temperary small 1500 engine with dual port heads and IDF 36's.
Greetz
Wim
Wunder Wim
« Reply #27 on: April 22, 2011, 09:27:46 am »
So as promised, some pictures of the wheels that have arrived yesterday.
Get ready for some wheelporn:
I started to clean up the seats and doorpanels. You can see the difference between the clean seat and the not cleaned yet seat.
Also cleaned up a doorpanel. Looks good for over 40 year old interior.
Next on was give the frontbeam a coat of paint:
So that's it for now. See you back soon for more updates.
Christoph
« Reply #28 on: April 22, 2011, 11:09:58 am »
wim, beautyful car.
What did you use to clean the interiour?
cheers, christoph
Wunder Wim
« Reply #29 on: April 23, 2011, 20:34:28 pm »
wim, beautyful car.
cheers, christoph
Hi Christoph,
I've used a steam cleaner I bought very cheap (Belgian readers should read this as 'in den Aldi') to clean the doorpanels and seats.
Greetz
Wim
