October 13, 2026, 00:05:03 am
| | |-+  What bolts/nuts for Erco rims?
Author Topic: What bolts/nuts for Erco rims?  (Read 13292 times)
Holmes
« on: May 01, 2006, 22:59:56 pm »
Which type of bolts/nuts are used for Erco rims (street version)? The original beetle ball-seat bolt seem to fit quite well but not perfect.
Roman
« Reply #1 on: May 01, 2006, 23:39:07 pm »
I have 14 mm press in studs from CSP in Sweden and tranporter nuts. If I remember correct the brand on the studs was Bugpack.
Note: You have to have special washers on Ercos.
Holmes
« Reply #2 on: May 02, 2006, 07:40:33 am »
Where do you get these washers? Are the washers centered in the bolthole or are they flat on the backside?
Roman
« Reply #3 on: May 02, 2006, 16:05:27 pm »
Flat on the backside. I bought mine from Tim Moores at HSL racing in the UK and if I remember correct they were less than a € each.
tim.moores@hslracing.com
SOB/RFH
Have fun!!
« Reply #4 on: May 02, 2006, 16:20:05 pm »
ROMAN!!!!!!!!!!!!!!You are NOT supposed to lighten the brakes....Does not apply to the rules of dragracing. As you have a street car pretending it is a race car you will end up in discussion with the tech inspectors.........(How do I know!! Smiley )
Even Erco has the washers.......
Roman
« Reply #5 on: May 02, 2006, 17:11:42 pm »
Who says this is my car?  Grin Grin Grin Grin
SOB/RFH
Have fun!!
« Reply #6 on: May 02, 2006, 18:37:10 pm »
Roman, it's a dead give away...........Who else paint and machine the drum like crazy and leaves the cup in a rusted state Smiley
Roman
« Reply #7 on: May 02, 2006, 18:59:04 pm »
At the tech inspection:
-Do you have lightened drums? Thats illegal!
-No sir, those are aftermarket drums with bigger holes for easier adjustment! Wink
SOB/RFH
Have fun!!
« Reply #8 on: May 02, 2006, 19:21:14 pm »
I like them!!! Cool and light!! When you get that motor done you are going to be the one to hunt!!! Keep up the good work Roman!!
Holmes
« Reply #9 on: May 02, 2006, 20:27:38 pm »
The only concern I have is how the rim is centered on the drum. If the washer is flat on the backside, IMO there is nothing that centers the rim. The hole in the rim has some sort of ball seat but thatīs not used with the washer then?
SOB/RFH
Have fun!!
« Reply #10 on: May 02, 2006, 20:32:40 pm »
With Erco wheels the studs themself centers the wheel on the drum, not the center of the drum. The holes are drilled so precisly that it is sometimes very hard to fit them the first time. The washers make up a seat for the swiwel on the nut.
Holmes
« Reply #11 on: May 02, 2006, 21:32:50 pm »
I measured the holes on my rims to about 15.5mm. Thatīs not very tight on a 14mm stud.
Hereīs a pic of the hole and seat:
Petter Carlberg
« Reply #12 on: May 03, 2006, 09:08:30 am »
Ercos catalog says "Alu wheel washers,nessesary with all 0,125" drag wheels"
If you have the 0,190" and a ball seat made in them, I think itīs just to bolt them on, ask Eric at Erco (If he ansvers!) he should know.
WheelieNelson
« Reply #13 on: May 03, 2006, 09:25:30 am »
why cant you use std chromed T1 bolts? I mounted wheels from CMS yesterday using std 12mm bolts. Since the wheels are made by the same hand i guess its the same hole Smiley They look the same.. Only difference was that i had to use longer bolts.
« Last Edit: May 03, 2006, 09:27:55 am by WheelieNelson » Logged
SOB/RFH
Have fun!!
« Reply #14 on: May 03, 2006, 12:10:36 pm »
I have only used .125" wheels from Erco and they are flat with no countersunk in them. Erco makes has his own drill fixture for his rims and it is done in house. The area of the section meeting the bolt gets bigger with this metod and increases the ability to withstand torque from a violent start.
« Reply #15 on: September 07, 2010, 19:20:55 pm »
The front could be easely centered with some centering bushings, what about the rear wheels ? I will have 14 mm studs.
I'm thinking of a "2 way" washer....One side bushing the bolthole in the wheel, the other side "accepting" whatever wheelnut ??
Thanks,
Harry
