September 25, 2026, 02:58:47 am
| |-+  For sale!
| | |-+  Turbo & performance parts clear out
Author Topic: Turbo & performance parts clear out  (Read 3725 times)
CarlosBP
« on: November 29, 2010, 22:47:43 pm »
Hi,
Got a range of parts I'm trying to clear out before loosing my garage in January.
First up a Genuine Garrett T04b turbo with K&N filter, oil lines & Copper gaskets.  £400
(Type iv oval port exhaust manifold is available free but needs some work after being modified for mounting turbo above the gearbox in a buggy)
Good for up to 500BHP
next up a custom made EFI setup for a type iv.
Comes complete with one injector per cylinder plus 5th injector for cold start, plus all sensors. These are all Bosch EFI parts from a GM motor. £250
I then have a Megasquirt ECU with loom.
This is currently setup with the MS1-E code version 02Y94, with 2 spart outputs, Tach out and 36-1 trigger. £sold
Brand new Bosch wide band Lambda sensor now available seperatly £60 part number 6G9N-9F472-HA
I also have a fully machined Type iv pulley with 36 tooth trigger wheel for the timing. This can go for £80 or as a swap for a normal ally type iv Porsche cooling conversion pulley.
next up a Minnow fish blow through carb - moddified with extra large float chamber (came off 2.2Lt Type IV engine with above turbo). Comes with Type IV manifolds, Stainless airbox with billett adapter & adjustable blow off valve - £150 ono
and finally 2 x oil coolers - £10 each
All parts are located in Southend and are plus postage.
« Last Edit: January 03, 2011, 19:47:03 pm by CarlosBP » Logged
CarlosBP
« Reply #1 on: November 29, 2010, 22:48:43 pm »
With some additional pics of the EFI fitted and including the bottom pulley/36-1 trigger wheel.
CarlosBP
« Reply #2 on: November 30, 2010, 17:18:01 pm »
Megasquirt now sold but lambda sensor still available.
CarlosBP
« Reply #3 on: January 03, 2011, 19:47:53 pm »
New year bump
