September 02, 2026, 00:23:09 am
Latest Member: Lotus67
| | |-+  Billet Hockey Stick
Author Topic: Billet Hockey Stick  (Read 8348 times)
Allen Wiess
« on: December 02, 2010, 17:29:18 pm »
Went by Dave Folts Transmission the other day to drop off some stuff and he showed me a new item that will be going in my tranny this winter.  They are getting beat on in an off road car now.  He has one for type 1 and bus box conversions.
Geers Engineering / LAT Lubricants
Rasser
« Reply #1 on: December 03, 2010, 21:12:59 pm »
Nice!
1955 type1
1966 type2 13w deluxe
« Reply #2 on: December 04, 2010, 11:06:07 am »
is this secured with two allen bolts? will that hold? just curious, not in any way to misprice the craftmanship, as this looks good.
« Reply #3 on: December 05, 2010, 00:33:29 am »
Or two roll pins?
Allen Wiess
« Reply #4 on: December 06, 2010, 23:21:58 pm »
Or two roll pins?
Pinned and welded on the end.
« Reply #5 on: December 07, 2010, 04:05:59 am »
Say they're available for use in Berg-5s and I'm in for a few!
Allen Wiess
« Reply #6 on: December 08, 2010, 19:18:48 pm »
Call Dave @ 909-923-5970 and ask him.
« Reply #7 on: December 08, 2010, 20:30:37 pm »
Or two roll pins?
thanks
« Reply #8 on: December 09, 2010, 01:46:17 am »
Thanks, will do ...
« Reply #9 on: December 09, 2010, 05:37:48 am »
I don't think it can be done.  There just isn't enough room in the nose cone of a B-5.
Here's a pic of the B-5 hockey stick.  When you pull it into R, 2nd, or 4th, the shaft of the hockey stick is burried in the bushing of the nose cone within a couple of mm from where the ground dia ends at the corner.
Then, look at the outside of the heel.  You can just see how it has a flat ground on it so it will clear the special nut on the mainshaft.  The reason Gene went with his custom design nut instead of using the stock hex nut was for clearance with the hockey stick when in 1st, 3rd or 5th.  Things are really close in there.
Note the TIG weld on the inside of the corner to add strength that was removed by grinding on the heel.
« Last Edit: December 09, 2010, 05:43:37 am by Bruce » Logged
