November 02, 2026, 18:13:13 pm
Checking cylinders for round - how?
Topic: Checking cylinders for round - how? (Read 13347 times)
jamiep_jamiep
December 09, 2010, 00:13:22 am »
Any what tools are needed?
Thanks!
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Re: Checking cylinders for round - how?
December 09, 2010, 01:57:52 am »
A dial bore gage, you check the cylinder going around for roundness and up and down the cylinder for straightness. To me, that is the only correct way to do it. Can use an inside mic. but is a hassle and not as accurate.
Ted
bugnut68
December 09, 2010, 02:08:26 am »
Quote from: racecraf on December 09, 2010, 01:57:52 am
Ted
x2!
Dial-bore gauge was a handy tool I purchased some time back. Was able to verify a used set of 90.5 "B" cylinders I bought were good to go with a good hone job. Can't go wrong investing in tools.
December 09, 2010, 02:38:48 am »
Thank you Ryan, This is 30+years as being a Machinist.
Ted
bugnut68
December 09, 2010, 03:09:01 am »
Quote from: racecraf on December 09, 2010, 02:38:48 am
Ted
There's no substitute for the proper tool!
I just scored a Mitutoyo (spelling??) depth mic, though missing a couple anvils, for $10 at an estate sale recently... I was pretty stoked, to say the least!
December 09, 2010, 03:35:26 am »
Ryan, thats a good deal, but ya need to make sure it's accurate. The anvils are adjustable, if there is a small machine shop near you, you might want to see if they can calibrate/check'em out. Just my 2cents.
Ted
December 09, 2010, 03:37:27 am »
The 0-1" anvil you can do on something very flat, but the other anvils need to be checked.
Ted
bugnut68
December 09, 2010, 03:42:19 am »
Good to know, will check it out! Worst case scenario I'm only out 10 bucks...lol. I"ve got a brand new depth mic I bought earlier this summer, too, so I'm not completely without one that's in spec.
December 09, 2010, 04:09:14 am »
The old set will be just as good as your new set after calibration, good to have a back up. I love tools....it's neat to go in your toolbox and get what ya need to do the job right.
Ted
jamiep_jamiep
December 09, 2010, 08:40:50 am »
Thanks for the info guys!
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
December 09, 2010, 09:09:50 am »
Question;
How do you know that they are round after you have torqued the head?
From the low reading on your compression tool?
Poor results on the leak down test?
Rings not sealing?
The blue smoke out your exhaust?
Low HP readings?
Low ET?
http://www.youtube.com/v/goNVh8Dsspc
December 14, 2010, 21:07:07 pm »
Thanks for sharing BB ! Another lesson learned. Now, i just purchased a set of 94 Wiseco pistons w/ Mahle cylinders. I'm searching high and low on the net but only find different figures, opinions etc. on side clearance.
Right now i'm waiting on reply from Pat Downs. But what would be youre or anybody here on the Lounge's opinion.
Thanks,
Harry
Paul Bate
December 14, 2010, 21:28:10 pm »
Hello FDK/Hurry,
I've used the same set up for 5+ years on the road and with a little shot of NOS and you need to have 5 1/2 to 6 thou piston to barrell clearence. The ring gaps also need to be bigger than stated by Wiseco as we are aircooled! I usually take the next highest ring gap to the state of tune on the instructions.
I hope this helps
Kind regards
Paul
Instagram: flatfourperformance_vw
Real street since 1994 drive to the track race and drive home no bull !
11.49 Natually Aspirated
10.79 Nitrous
1960 lbs with driver!
December 14, 2010, 22:26:47 pm »
Thanks Paul !
PM to you.
Best Regards,
Harry
December 14, 2010, 22:51:24 pm »
So i will go 0.15 mm (tight) on side clearence. 0.12 mm top-ring and 0.14 mm 2nd ring.
Last Edit: December 15, 2010, 18:42:59 pm by FDK/Hurry
