September 24, 2026, 23:51:20 pm
| |-+  For sale!
| | |-+  For Sale - the Jagerbugs 1914 Race engine - best time 14.8
Author Topic: For Sale - the Jagerbugs 1914 Race engine - best time 14.8  (Read 3731 times)
AlexB
« on: December 10, 2010, 20:44:45 pm »
Due to upgrades ready for next season our 'old reliable' 1914 engine is up for sale - this is a complete engine with tinware, alternator etc - will not come with carbs/manifolds or Dizzy - but everything else
If you search back through the jagerbug build threads you can find the pics of this being assembled - spec as below
1914 cc Wbx cranked type 1 case
Dual relief case modded to take counterweighted wasserbox 69mm crank running a 210mm lightened flywheel and a 210mm van pressure and centre plate
engle 120 cam, straight cut cam gears, 26mm schadek pump, fullflow oiling with all filter mount and pipework/filter included,
Pistons match weighted and rods matched too
Cut to length moly push rods, bolt up rocker shafts, stock heads modded to take dual valve springs and ports hand ported.Compression ratio upped to 9-1
Tinwear/fanshroud/alternator /pulleys etc inc
Basically - bolt on a set of carbs, add a dizzy and exhaust & you are ready to run
This engine has done over 200 passes on the strip, some road miles too & pulls like a train - its still in the car so if you want to test it prior to purchase its not a problem - it was given a full check over and service/oilchange prior to Vw action in sept - has done about 20 miles since then Cheesy
This was taken at vw action
<a href="http://www.youtube.com/v/Nask99trrzU" target="_blank">http://www.youtube.com/v/Nask99trrzU</a>
Its a top laugh to drive on the street - plenty of power but still idles like a stocker in traffic and runs cool
We had'nt planned to sell this as its been our spare but we really want to get the 2276 back in for next season and need the funds
hence £ 950 gets you some rapid street action or a good bracket racing engine for next seasons VWDRC as its incredibly consistent Cheesy
AlexB
« Reply #1 on: December 27, 2010, 18:19:07 pm »
Sold  Grin
« Reply #2 on: December 27, 2010, 18:25:13 pm »
cool engine!
just out of interest, how come the WBX crank? nice touch though Smiley
AlexB
« Reply #3 on: December 27, 2010, 21:23:52 pm »
cool engine!
Because i had it spare & decided it would be stronger and more robust than a stock T1 - it seemed to be as it did over 200 passes on the quarter mile being revved to 6000 rpm Cheesy
