September 27, 2026, 02:57:06 am
| | |-+  My notch
Pages: [1] 2 3 4 Print
Author Topic: My notch  (Read 50605 times)
« on: December 12, 2010, 23:52:37 pm »
hello guys,
heres a first pic with my front wheels installed... Wink
« Reply #1 on: December 13, 2010, 00:09:34 am »
Looks good so far.Looking forward to see the car finished.  Smiley
« Reply #2 on: December 13, 2010, 09:13:49 am »
Nice!
« Reply #3 on: December 13, 2010, 09:58:24 am »
nice, but what we want to see is the big turbo engine  Grin
« Reply #4 on: December 13, 2010, 10:59:18 am »
Hey Nicolas,
I didnt work on the motor yet,
I still need to fabricate ALOT and buy some stuff...
I hope its finished before EBI (it should Smiley )
scored an early rear subframe for it yesterday, will convert it to IRS; i think it will be stronger with the framehorns..
« Reply #5 on: December 13, 2010, 12:06:21 pm »
Hey Nicolas,
yes it will be stronger and if you can replace the rubber supports that hold the frame to the rest of the floorpan with stiffer urethane or teflon ones. (i am trying to get those made if i take the trans out) and that will stiffen up the rearend as well.
and if you keep it IRS you need to weld in the brackets OR you can use the top of the IRS frame and the bottom on the early one, then there is no problem with the fiddling and measuring of the brackets.
enough about rearends and bottoms though
« Reply #6 on: December 13, 2010, 14:22:39 pm »
hey nicolas,
I read somewhere that type 3 detectives had the harder rubbers for the subframe..
« Reply #7 on: December 13, 2010, 18:06:59 pm »
here Nicolas:
http://www.typethreedetectives.com/parts-catalogue/rear-end/
« Reply #8 on: December 15, 2010, 15:26:27 pm »
Nice new project  Cool
« Reply #9 on: December 15, 2010, 16:53:57 pm »
yep that is what i mean.
« Reply #10 on: January 02, 2011, 16:25:00 pm »
Sold the Ghia today,
more money for the notch Smiley
« Reply #11 on: January 16, 2011, 22:04:57 pm »
hey Guys,
got my rear drums redrilled and installed today Smiley
I think i will keep her like that, without lowering it
Wünderwolff
aka Dr. Jeckill
« Reply #12 on: January 16, 2011, 22:26:21 pm »
Very nice!
Indeed looks good like this, has a certain element of agression in it's stance. Start with the engine now, see how it handles and go from there. Early notches were known to lift their noses at speed, that's why the nose was changed to creaye more downforce. Let's see what this fat chick will do.
Wünderwaffe are Go!
Flow
« Reply #13 on: January 16, 2011, 22:29:46 pm »
Looks very cool !  Shocked
What are your tire sizes ?
« Reply #14 on: January 16, 2011, 23:18:56 pm »
Nice !
« Reply #15 on: January 17, 2011, 00:38:29 am »
Hey Guys,
thanks Smiley
tires are 145 michelins and 185 70 vredesteins
Flow
« Reply #16 on: January 17, 2011, 01:16:05 am »
The 185 70 vredestein look fat on your car.
I though there were bigger.  Wink
« Reply #17 on: January 17, 2011, 10:09:11 am »
thanks a lot
I like em too Smiley
wolfswest
« Reply #18 on: January 17, 2011, 10:37:07 am »
no rubbing in the back?
alloys are 5.5 in the back?  do you know the ET?  I guess 5.5's are ET 45 ?  Huh
I also would like to use 185's on my notch, but my sprintstars are 5.5 ET 34.
is an IRS car wider then a sprinplate car?  Huh
« Reply #19 on: January 17, 2011, 11:38:35 am »
those are late 6" fuchs. you can google the ET i think. Wink
« Reply #20 on: January 17, 2011, 12:06:45 pm »
Hey Dem,
as Dieds said, they are late 6", dont know the ET,
I didnt drive her yet, so cant tell you they are rubbing or not..
they do come close to the wheel wells
IRS is wider is guess, but how much i dont know
Youll just have to try it Smiley
wolfswest
« Reply #21 on: January 17, 2011, 12:20:59 pm »
okay, thx D and P.
I'll give it a go.
« Reply #22 on: January 27, 2011, 20:48:59 pm »
Hey Dem,
I drove it around and no rubbing with the 185s
i can can just stick my fingers between tyre and fender...
nice car for cruising too Smiley
Felix/DFL
« Reply #23 on: January 27, 2011, 21:36:16 pm »
Hey Dem,
Here you can check your ET:
http://www.wheelerdealer.de/WD_technik_datesheet_porsche_wheels_en.htm
Page 2. nicely done by wheelerdealer.
Greetz!
71CALRIPPER
« Reply #24 on: January 28, 2011, 10:39:34 am »
Timeless wheels , make any car perfect
wolfswest
« Reply #25 on: January 28, 2011, 11:16:51 am »
Hey Dem,
Greetz!
Thx Felix!  car looks great, wheels make the car!
« Reply #26 on: February 07, 2011, 22:42:48 pm »
hey guys,
started to mock up the header and turbo.. Smiley
« Reply #27 on: February 28, 2011, 15:11:25 pm »
Well,
I decided, I will use a charge cooler, I dont like to have too many tubes and all that,
but its smaller and i wont have to cut holes in the car... would like to keep it looking stock...
so here it is:
still need to order, but its not expensive at all, and i will use an electric waterpump from a merc that i found for 15 euro Smiley
« Reply #28 on: March 12, 2011, 15:11:00 pm »
lowered in the front...
dont know what i like best; before or after....
and the new cooling system
« Reply #29 on: March 12, 2011, 16:44:59 pm »
nicely lowered, don't change a thing now  Wink
