September 27, 2026, 02:57:13 am
| | |-+  My notch
Pages: 1 2 [3] 4 Print
Author Topic: My notch  (Read 50606 times)
« Reply #60 on: August 18, 2011, 10:46:20 am »
Hey guys,
Some more crap keeps popping up:
oil leaks, almost no oil pressure, intake leaks (i think)...
i think i have an intake leak, because 3 and 4 side is getting much hotter...
will try with some brakecleaner tonight.. F###CK! i m getting tired of it  Angry Angry
« Reply #61 on: August 18, 2011, 10:51:13 am »
Hey guys,
Come on Peter, do not give up! The break cleaner / start gas test will give you a answer ASAP. Or you can try to make a adapter and used your compressor to test the turbo system / intake system for leaks.
« Reply #62 on: August 18, 2011, 11:37:32 am »
Thanks Kalle  Wink
will try a few things tonight.....
Wout
« Reply #63 on: August 18, 2011, 21:01:52 pm »
Good luck, it's part of our hobby  Grin
gr Wout
Aircooled vw's for life!
« Reply #64 on: August 20, 2011, 19:07:41 pm »
hey guys,
did some work today...
took off the sump to be able to install the stiffer spring and other piston at FW side ...
maybe its normal, but the cow magnet was filled with metal debris...
i hope its from breakin...
will show a pic of it later
anyway, installed everything again and cranked for oil pressure....
nothing....even after a long time cranking  Cry Cry
next, i ll take off the pump cover and otherwise it will have to come apart again...
i did prime it but didnt hepl now...
« Reply #65 on: August 20, 2011, 21:22:46 pm »
pic of the magnet....
tell me if it looks bad Huh
i didnt find any aluminium flakes from the bearings though in the oil
cheers, Peter
Sander/DVK
« Reply #66 on: August 20, 2011, 22:36:41 pm »
Outch, I hope the best for you Peter.
« Reply #67 on: August 21, 2011, 12:14:04 pm »
yikes, what's that coming from?
« Reply #68 on: August 21, 2011, 13:00:43 pm »
i guess the cam  Angry Angry
its metallic, so it cant be the bearings
henk
« Reply #69 on: August 21, 2011, 13:25:34 pm »
not sure but looks like quite a bit of metal to me.
most be metal as it sticks to the magnet.
henk!!!
« Reply #70 on: August 21, 2011, 22:36:04 pm »
hey guys,
just checked the oil pump and it looked ok,
but while reassembling, i noticed that i connected the oil filter backwards!!!!
this must be the stupidest mistake ever  Cry Cry
i can kick myself in the head now Smiley
i guess this explains my low oil pressure
wolfswest
« Reply #71 on: September 18, 2011, 19:29:24 pm »
hey buddy, You gave up or still fighting to get to DDD?  Huh
Hope to see you there with the notch!
« Reply #72 on: September 18, 2011, 21:17:12 pm »
Hey Dem,
still fighting Smiley
I rebuilt the complete engine because cam, lifters and all bearings were gone
i got oil pressure yesterday and tried to start it today, but no luck...
hopefully tomorrow this bitch fires up or i ll start to pull my hair out Smiley
i also just installed the outer valve springs for breakin, so hope the cam and lifters wont fail on me this time
wolfswest
« Reply #73 on: September 19, 2011, 11:30:27 am »
sounds good man, I'll pray day and night and I'll visit "scherpenheuvel" with 659 candles to burn for you!  Grin
GO GO GO!
« Reply #74 on: September 19, 2011, 20:34:38 pm »
Damn !
« Reply #75 on: September 19, 2011, 23:03:23 pm »
SHE RAN!!!!  Grin Grin Grin
now tuning, install the innner springs and maybe i can drive to ddd
volkskris
« Reply #76 on: September 20, 2011, 01:23:24 am »
it sounded good  Grin
Wout
« Reply #77 on: September 20, 2011, 12:30:39 pm »
Good luck!!!
gr
Wout
henk
« Reply #78 on: September 27, 2011, 10:07:59 am »
did you not make it with the engine?
didn't see your cat at DDD,more problemes?
henk!!!
« Reply #79 on: September 27, 2011, 11:46:58 am »
hey Henk,
I made it there,
but i destroyed my gearbox when I went to the burger king...  Roll Eyes
« Reply #80 on: September 27, 2011, 11:52:32 am »
Dam Peter, that`s why they call it FAST FOOD! Very dangerous for weak gearboxes  Smiley
« Reply #81 on: September 27, 2011, 15:03:21 pm »
HAHA Smiley
we didnt get there fast though Smiley
henk
« Reply #82 on: September 27, 2011, 19:01:29 pm »
so you destroyed it before could look at it,that was fast.
at least you got the engine running,that's good.
henk!!!
volkskris
« Reply #83 on: September 27, 2011, 19:50:32 pm »
time for a mendy  Grin Grin
« Reply #84 on: November 03, 2011, 13:19:51 pm »
small clip from the weekend if you dont mind:
<a href="http://www.youtube.com/v/wgq5qbCn0Z0" target="_blank">http://www.youtube.com/v/wgq5qbCn0Z0</a>
cheers, P
« Reply #85 on: November 03, 2011, 13:24:53 pm »
Ah... thanks for posting.
So... happy?
« Reply #86 on: November 03, 2011, 15:06:30 pm »
Hey Kalle,
For now, I am happy Smiley
allthough i am only at 10 psi pussy boost yet Smiley
the original gearbox is getting tired quick  Grin
lowfastbus
WUNDERWAFFE
« Reply #87 on: November 04, 2011, 20:27:01 pm »
Nice Peter!!
When is the real box coming??
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
« Reply #88 on: November 05, 2011, 11:05:53 am »
hopefully today Smiley
found a 091 Smiley
Wout
« Reply #89 on: February 01, 2012, 20:24:38 pm »
Updates?
gr
Wout
