September 10, 2026, 13:22:54 pm
Latest Member: Bad Habit
| | |-+  About calculating an engine
Author Topic: About calculating an engine  (Read 5634 times)
vintagewagenwerks
« on: December 26, 2010, 14:26:18 pm »
Post here your methods about calculating your engine project especially choice of valvesices and camshaft by calculating the peak rpm.Share your experiance here.
Itīs better to burn out than to fade away.
« Reply #1 on: December 26, 2010, 14:55:41 pm »
I think this will be a thread with very few answers. Why? Because most people out there build their engines from:
1) following a www recipe
Or
2) copying a engine built earlier
vintagewagenwerks
« Reply #2 on: December 26, 2010, 15:44:52 pm »
Maybe some engeneers were here to tell something about
« Reply #3 on: December 26, 2010, 16:22:57 pm »
I believe engineers drive Porsche Smiley
vintagewagenwerks
« Reply #4 on: December 26, 2010, 16:40:50 pm »
i thought about JPM or some experience about ugly duckling
« Reply #5 on: December 26, 2010, 16:42:51 pm »
I think experiance is the best calculator. But therefore you must know what you want  Smiley
vintagewagenwerks
« Reply #6 on: December 26, 2010, 17:07:00 pm »
what i want is quiet as simple ,my plans a 2276cc super street and racing engine.
Some specifications in my plans are to use a standart AS41 case machine for 82 stroke and 94 piston bore ,Scat volksracer Cam ,scat 5500 pleuel 22 bolt on .Mahle + Pistons and cylinders .Angleflow heads ,about the choice of the valve sice i going to plan 48in and 38 out some people tells that 46 / 37 would be better in case of reaching a peak power at nearly 7500rpm and max torque by 5500 to 5700rpm so how to calculate the right camshaft ,valves ,valve springs ,, pushrods and rocker arms conversion.
