September 24, 2026, 01:36:56 am
| | |-+  Gasburner Question
Author Topic: Gasburner Question  (Read 9096 times)
christ4
« on: December 30, 2010, 18:45:35 pm »
Hi I´ve got a question for use gasburners on a beetle. Do I need Wheel Spacers? In the front or in the back? The offset is 40? Am I right?  Huh
 What are your experiences?
I would be grateful for any infos?
Andy Sykes
« Reply #1 on: December 30, 2010, 20:01:27 pm »
hi i run 7mm spacers on the front and 20mm on the rear but im running 944 turbo brakes with 4 pots on, it all depends on what brakes you have
cheers andy
« Reply #2 on: December 30, 2010, 21:09:45 pm »
Please do a search, there is plenty of Gasburner info to be found and you need to add more info to your post. What year is your bug etc etc.
If you have 67 or later axles you do not need spacers at the rear. At the front it all depends on your set up but in most cases you do not need spacers unless you use one of those ugly, narrowed beams. (sorry fast65)
Andy Sykes
« Reply #3 on: December 30, 2010, 21:29:05 pm »
lol no offence iit is 4" beam but all part of the plan with the dropped spindles and brakes its stock now Smiley. can fit 14" fuchs no probs but not burners without spacers Smiley
cheers andy
thejohn66
« Reply #4 on: December 31, 2010, 01:20:27 am »
Mine is a '66 with 2" narrowed beam (dropped spindles,ghia discs and talbot sunbeam calipers) no spacers required. Rear has been converted to short axle with type 3 drums 205/65 tyres and need a 3mm spacer to make the clearance comfortable. slightly thinner tyre and I'm sure no spacer required. Hope his helps, Alex
Bitburg motor boating club member.
« Reply #5 on: December 31, 2010, 04:53:40 am »
.... iit is 4" beam
You will need to run a 2" spacer with that.
Best is to take out the silly narrowed beam and put a stock one in.
christ4
« Reply #6 on: December 31, 2010, 10:04:21 am »
Yes I´ve a later model, so no problem at the rear. I have original setup at the rear and would drive 205/70 tires. In the front I have an original (welded) adjustable axle. And there are no problems to fit the hub caps?
Andy Sykes
« Reply #7 on: December 31, 2010, 14:56:15 pm »
.... iit is 4" beam
lol if i did tha the wheels would be sticking out by 2" each side now that would look silly Smiley
cheers andy
« Reply #8 on: December 31, 2010, 15:53:55 pm »
I have a stock beam with 17 mm spacers on my 65, and the gasburners fits like a glove in my eyes. No drop spindles though.
christ4
« Reply #9 on: December 31, 2010, 17:52:23 pm »
ok. do you have any pics of the car? and the hub caps fit?
« Reply #10 on: December 31, 2010, 21:41:23 pm »
.... iit is 4" beam
cheers andy
You don't understand what 42mm of offset means.
My buddy's 66 used to have a 2" narrowed beam.  He took that out and put in a stock beam when he switched to original Mahle wheels.  Nothing sticks out.
Chris W
« Reply #11 on: December 31, 2010, 22:57:05 pm »
I think this is the car Bruce is talking about.
Here is mine. Stock beam, drop spindles/disc and 145's up front, Type 3 drums with a 10mm spacer and 205/70's in the rear.
« Last Edit: December 31, 2010, 22:59:10 pm by Chris W » Logged
fredy66
« Reply #12 on: January 01, 2011, 01:34:14 am »
.... iit is 4" beam
cheers andy
http://www.rimsntires.com/rt_specs.jsp
arabia slugs
Andy Sykes
« Reply #13 on: January 01, 2011, 12:21:06 pm »
.... iit is 4" beam
cheers andy
yes i do Roll Eyes i built the car it has dropped spindles 1" lost porsche brake conversion 1" lost = stock so trak is now standard the only reason i run spacers is to clear the calipers
thanks andy
« Last Edit: January 01, 2011, 12:42:30 pm by fast65 » Logged
