September 22, 2026, 07:14:11 am
| | |-+  Combination Oil filter/pumps
Author Topic: Combination Oil filter/pumps  (Read 14630 times)
« on: January 05, 2011, 03:09:19 am »
Are filter/pumps really as bad as I've heard they are? I'm rebuilding my engine and spending far too much money on it. Reliability, longevity and period correctness are my primary concerns. Due to my inherent stubbornness, that leaves me stuck with the EMPI filter/pump, or no filter at all. What makes them so bad? Can they be improved? The part that bothers me most is the huge 32mm gears, my oil pressure would be off the charts, would it not? Is it possible to use it with a smaller 26mm pump? Thanks!
« Reply #1 on: January 05, 2011, 03:17:47 am »
Put that Empi Pump/Filter in a Display Case and tap the case for full flow use a Blueprinted Berg 26mm Pump and Cover Problem Solved
« Reply #2 on: January 05, 2011, 03:22:16 am »
It's already tapped if I choose to go that route. But I'd rather not. Berg < EMPI  Wink
« Reply #3 on: January 05, 2011, 03:27:02 am »
Berg=Best < EMPI=Ok!!   more for looks then good filtering  Wink plus with the oil filter mounted sideways it drains back in to the case so on starting it has to fill the filter before your bearings get any oil
« Reply #4 on: January 05, 2011, 03:29:57 am »
X2
« Reply #5 on: January 05, 2011, 04:21:46 am »
period correctness are my primary concerns  Berg Was Selling the same pumps and covers when your car was Built New
Jim M
« Reply #6 on: January 05, 2011, 05:37:10 am »
I have built an engine using the old empi filter pump. They work fine. Oil pressure was good.Kobus now owns the car/engine, i believe it is still in service.I'm currently running a rajay filter pump with no problems....Jim
« Last Edit: January 05, 2011, 19:24:46 pm by Jim M » Logged
Porters Precision
« Reply #7 on: January 05, 2011, 17:48:18 pm »
So that means any part built when my car was new is good for it? I think not. Maybe period correct isn't specific enough. If it was anything else than a GTV I wouldn't hesitate to use a Berg cover (hell, I've got one or two on my shelf), but it is a GTV so I feel obligated to give it the parts that EMPI would have deemed fit for it. Once again, the car owns me rather than the other way 'round Roll Eyes
alex d
« Reply #8 on: January 05, 2011, 18:22:47 pm »
being that specific car I would run the EMPI filter pump with no hesitation, as long as the pump is in good shape that is!
« Reply #9 on: January 05, 2011, 23:55:52 pm »
I have one on my GTV motor.
Also at one time Empi made high volume oil pumps by modifying Automatic Stickshift pumps.
« Reply #10 on: January 06, 2011, 00:00:13 am »
That was also an option I thought of, I have an auto-stick pump in stock.
How is an auto-stick pump modified for a full flow? I asked on here a while ago but got no answers Roll Eyes
« Reply #11 on: January 06, 2011, 02:57:13 am »
LOL Here you Go Zach use a Berg Pump And A E**I full flow Cover and Now the GTV is All EMPI   LMFAO
« Reply #12 on: January 06, 2011, 03:11:28 am »
So Gary,
This is your version of "Old School Is The Only School" ?
Shame on you !
 Roll Eyes
rick m
« Reply #13 on: January 06, 2011, 03:21:03 am »
Zach,
Run the Empi pump. You'll be fine.  I had one on the early years and blew a few oil seals out of it on cold Sacramento mornings when it froze overnight.  See Steve Hollingsworth about a mod he does on the front of the case for this issue. I would not be afraid of running the pump. I still have an old one too and would run it if building a nostalgia motor.
Rick Mortensen
Rick Mortensen
Driving Hot VWs since 1970
« Reply #14 on: January 06, 2011, 16:02:55 pm »
i've run an empi oil filters/pumps on my speedwell/empi engine and never have any problem with this one , it's the one with the 32mm pignons
« Reply #15 on: January 06, 2011, 22:25:42 pm »
Wow, if Rick says it's ok to use vintage parts, it must be OK! Wink
I'll have a talk with Steve to see what we can do. He wasn't very hip with the idea last time I mentioned it Roll Eyes
« Reply #16 on: January 06, 2011, 22:38:16 pm »
monkiboy has run a 32mm oil pump for years now. though it is full flowed and running an additional cooler.
do what makes sense. i'd say it'll be fine, not optimal, but sufficient at the least.  Wink
« Reply #17 on: January 06, 2011, 23:41:49 pm »
So Gary,
Shame on you !
 Roll Eyes
LOL Richard Sorry I Used a Page from your Favorite Catalog LMAO!  I would Not Use Any New Empi Crap as Far As The Old I Have A NOS Oil Pump/Filter  But It will never go On one of My Motors its in a Display Case Where it Belongs I Would only use a Berg BluePrinted Pump 26mm after all you don't need alot of Oil Pressure.  Volume is what you want
« Reply #18 on: January 06, 2011, 23:47:14 pm »
It's restriction to flow that creates pressure, if one makes sure the bleed valve near the flywheel flow enough you won't have any problems with a huge pump.
rick m
« Reply #19 on: January 07, 2011, 05:17:53 am »
JHU,
You nailed what we've been doing on our cases.  The front oil piston area is where we relieve and enlarge the dump hole so it does not allow pressure to over build. My cases so far have run consistently well with this mod. We also spot face the base where both pistons meet the case material so they seat better and don't bleed off pressure when you need it.
Rick M
Rick Mortensen
