November 03, 2026, 05:00:59 am
| | |-+  How to fit a new degree ring on a berg pulley?
Author Topic: How to fit a new degree ring on a berg pulley?  (Read 7450 times)
FDK/mrpedrini
« on: January 13, 2011, 23:08:05 pm »
As the title says...... Maby a blunt question...
I'm about to restore an old berg pulley (sand blasting, new zink plating and new degree ring). I ordered a new ring but it doesn't seem to stick. There is some kind of substance on it... Does it needs some special treathment (heating) or should i put glue on it?
Kind regards...
Dennis
« Reply #1 on: January 13, 2011, 23:13:44 pm »
Dude  Huh Throwing away the instructions again and see what happens ? Grin See me.
« Last Edit: January 13, 2011, 23:15:46 pm by Harry/FDK » Logged
FDK/mrpedrini
« Reply #2 on: January 13, 2011, 23:16:23 pm »
Yeah?
FDK/mrpedrini
« Reply #3 on: January 13, 2011, 23:18:59 pm »
There were no instructions inclueded.... so tell me your secret! Grin
« Reply #4 on: January 13, 2011, 23:32:03 pm »
Come over and get this sorted.
FDK/mrpedrini
« Reply #5 on: January 13, 2011, 23:36:59 pm »
Ok, i'll give you a call this week end... Btw.....case looks nice!! Grin Maby give it a full on polish Tongue
Jim M
« Reply #6 on: January 14, 2011, 20:16:56 pm »
If it is a berg degree ring, you need acetone to wet the bonding agent. It needs pressure over night on it.....Jim
Porters Precision
« Reply #7 on: January 14, 2011, 20:21:01 pm »
In the past I have used propane torch to lightly heat to remove old ring to be replace.
FDK/mrpedrini
« Reply #8 on: January 14, 2011, 22:42:30 pm »
Ok! Thanks for avice guys!
kind regards,
Dennis
Zündfunke
« Reply #9 on: January 14, 2011, 23:35:16 pm »
Where can you order a ring separately...in europe? Undecided
« Last Edit: January 14, 2011, 23:57:45 pm by Zündfunke » Logged
BURN OUT Syndrom
« Reply #10 on: January 14, 2011, 23:59:44 pm »
Not. Only Berg. Good Luck ZF.
Zündfunke
« Reply #11 on: January 15, 2011, 00:06:12 am »
... Embarrassed... that´s what I thought.
BURN OUT Syndrom
Speed-Randy
« Reply #12 on: January 15, 2011, 03:31:20 am »
Berg says use acetone on pulley to clean it, locate where TDC is, apply acetone to ring to activate the glue on back and apply to pulley. Set pulley face down with something heavy on top of it, leave overnight and install on crank. Hope this helps
eugene
« Reply #13 on: January 15, 2011, 10:05:37 am »
My degree ring was packet by bugpack but it says gene berg on it. I have bought it some 5 ago. I dont know if this is still the case but you could try this route.
Jesse/DVK
'64 2176cc
« Reply #14 on: January 15, 2011, 15:48:09 pm »
www.kaagkevers.nl
http://www.kaagkevers.nl/shop.php?id=10075
EUR 6,50
