November 02, 2026, 19:55:30 pm
| | |-+  broken screw thread oil pump
Author Topic: broken screw thread oil pump  (Read 6342 times)
vintagewagenwerks
« on: January 17, 2011, 18:35:39 pm »
hey guys ,today iīve build of my oilpump because itīs leaking and i realised that one of the screw threads is damaged ,in the past someone have repaired it by helicoil ,the drilled whole is 10mm at now so a M8 repaircoil does not fit and the try to fill the whole with power metal and fix a repair coil in does not work safely because you can not tighten the screw as hard as it have to be 25 NM of torque maybe it is 15 now so have someone an idea how i can fix this problem correctly.the engine do not loose much oil at the screw but it is annoying .The pump is screwed by scews and copper rings not by nuts
Itīs better to burn out than to fade away.
« Reply #1 on: January 17, 2011, 18:59:51 pm »
That's the original cause of the problem. The threads in the case were never designed to have bolts screwed in and out – the metal is too soft for that. That's why the factory used studs. I am sure you can have a new threaded insert put into the case (they are available in a variety of inside and outside diameters) and then install a stud – or rather, install FOUR studs and secure the oil pump that way. Maybe use an industrial epoxy to secure the stud, too. Don't use bolts straight into the case…
vintagewagenwerks
« Reply #2 on: January 17, 2011, 19:09:44 pm »
the problem with the epoxy i have used is that this is to soft to drill exactly for a repair coil .so the repair coil does not seem to replaced as good it have to be.the diameter of the drilled whole is by 10mm so to big for a 8mm screw thread ..so usin an m 10 repair outside and m 8 inside thread do not work, that my problem .are their some special epoxys you thinking of?
« Reply #3 on: January 17, 2011, 20:26:13 pm »
You could try using a Time-Sert Bigsert, like this ...
http://cgi.ebay.com/ebaymotors/BIG-SERT-NEW-5812-M8-X-1-25-SECOND-THREAD-REPAIR-KIT-_W0QQcmdZViewItemQQhashZitem41556f89dbQQitemZ280606247387QQptZMotorsQ5fAutomotiveQ5fTools
However, for the best results, I'd use a drill press or milling machine which means the engine would have to be out of the car ... Tongue
Also, I'd check to make sure this will fix that large of a hole before purchasing! Might also be TOO BIG ...
Good Luck!
« Reply #4 on: January 17, 2011, 21:09:27 pm »
I'm with Tom, if you go Time-Sert the OD will be very close to M10. It could destroy your pump bore, but it is your best shot. Forget epoxy's, i'ts just glue IMHO.
vintagewagenwerks
« Reply #5 on: January 17, 2011, 21:16:57 pm »
thanks for your help ,i also tried it with somethin like this but this item seems to be better than mine i used v-coil repair for m8 but the insert is not big enough ,i knew this parts you send me in the link you can also use for make the screw threads of the pistons studs stronger they have m10 on the outside maybe a good result can be taken with a inch screw thread but i repair it when my 2276 engine will stand on my work bench ,the fear of a fault is to big ,at the time it is tighten no oil leaves the pump ,i turned the screw a little bit tight and clued it outside with epoxy .semms to be good for driving this season .
i clued it with this
http://www.petec.de/preloader_produkte.swf
« Reply #6 on: January 17, 2011, 21:34:28 pm »
In the past i tapped a Inch OD Timesert to Metric on the inside and screwed it in a "H%*A.... It worked. (Bitch to do).
