October 13, 2026, 11:02:26 am
| | |-+  Autometer and old ignition
Author Topic: Autometer and old ignition  (Read 8297 times)
Type1/DVK
« on: April 03, 2007, 13:47:59 pm »
My latest addition is a new Autometer Monster tach, you know, the usual stuff Wink and there is a small problem with combining it with a old ignition system from a stock 1200 engine.
The needle is bouncing up and down like crazy! Looks like it can't wait for EBI  Grin Cheesy
Is this the combo with autometer and the old dizzy/coil? or just a bad ground?
Anyone with similar combo (with 010?) with this problem?
« Reply #1 on: April 03, 2007, 15:12:51 pm »
Make sure the tach wire running back to the coil is clear of any spark plug wires.
« Reply #2 on: April 03, 2007, 18:00:26 pm »
Have you tried checking your dwell angle with a meter?  I have a 009 with points and like 46-48 degrees of dwell...plus, you can see on the meter if your distributor is shot (dwell bouncing around...should be a steady needle).  Make sure the batteries in your test instrument are good, too (I could tell you stories  Roll Eyes).  The other thing that comes to mind is the 12v power wire for the tach...make sure it's on the switched side of the fuse box.  I had mine on the hot side for a while (tach's ON all the time...not good).  Good luck!
Type1/DVK
« Reply #3 on: April 03, 2007, 20:16:28 pm »
mmm, the sparkplug wires.. thats a good one.. Shocked
Thanks Sarge, mine is on the 'switched' side, only needs a fuse in between..
Jordy/DVK
« Reply #4 on: April 03, 2007, 21:13:41 pm »
 Make sure you buy the right fuses. I bought the wrong holders for the slow acting types..  Lips Sealed
 Going to get some fast-acting 4 Amps + holder, and material for a mounting bracket soon...  Cool
 Hope I mine don't suffer from the "dancing needle disease"...
  "The Full-Throttle Cruisers"
