November 02, 2026, 21:10:13 pm
| | |-+  How do you run a smaller 356 dyno on a type1 engine??????
Author Topic: How do you run a smaller 356 dyno on a type1 engine??????  (Read 18052 times)
« on: January 20, 2011, 04:58:07 am »
Well again as the title says guys I have been thinking about running a smaller 356 dyno on my next type1 engine - I have seen it done a couple of time now namely on Pete's 1795cc Raptor motor (anyone got any pic's?)
So I am wondering whats involved Huh What parts do I need Huh Which dyno stand Huh which pulley's Huh which fan/backing plate etc Huh
Any help would be awesome guys  Smiley
edcraig
« Reply #1 on: January 20, 2011, 06:25:50 am »
It was a Bosch # GR26x.  A 12v generator, thats the same size as a 6v VW generator.  Just get a 6V generator stand, Pulley, and 6v generator tin.
« Reply #2 on: January 20, 2011, 12:32:41 pm »
Cool Thanks Ed - Thats just what I needed  Smiley
Anyone got a pic Huh Smiley
Dave Galassi
« Reply #3 on: January 20, 2011, 14:23:51 pm »
ovaldriver56
« Reply #4 on: January 20, 2011, 14:58:09 pm »
I love that manifold Kiss
« Reply #5 on: January 20, 2011, 16:51:11 pm »
The early backing plate is recessed and calls for an early narrow fan, correct? I would assume that a '66 backing plate would be flat, allow for a wider fan, and fit the 6v diameter dyno(?).
Good thinking, Lee. I've always thought that would be a great idea on a '66 and earlier car.
« Reply #6 on: January 21, 2011, 22:29:15 pm »
Good point on the fan Zach  Undecided
Anyone got any thoughts on Fanhousing/Fan Huh Huh Huh
Maybe someone who know's Pete's engine might drop in and help - Please  Wink Smiley
« Reply #7 on: January 21, 2011, 22:36:46 pm »
I know this is a 6v dyno but the fanhousing looks interesting  Undecided Smiley
http://cgi.ebay.com/ebaymotors/porsche-356-fan-shroud-6V-generator-_W0QQcmdZViewItemQQhashZitem230d9c77b5QQitemZ150552213429QQptZVintageQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Ron Greiner
DKP II
« Reply #8 on: January 21, 2011, 22:50:22 pm »
that is a 356 - 912 fan shroud and a 6 volt generator
Ron Greiner
DKP II
« Reply #9 on: January 21, 2011, 23:02:14 pm »
This would not allow the use of the later doghouse fan
« Reply #10 on: January 22, 2011, 00:27:06 am »
So I guess the main question is.... Where do I find an original  Bosch # GR26x.  A 12v generator Undecided  Huh Smiley
cel
« Reply #11 on: January 22, 2011, 01:52:47 am »
Hi!
Here are some 90mm 12v generators in shops which i think should work, but there are different types (with i think like 25a, 30a and 38amps) depends how many "elecrical users" (dont know the english name) you have in the car.
http://cgi.ebay.com/ebaymotors/Porsche-912-356-VW-BOSCH-Generator-12V-25Amp-90mm-/350432766827
http://shop.volkswarenhaus.de/product_info.php/info/p2838_Generator-12V-90-mm-Diameter.html
http://www.ge-ma-classics-shop.de/product_info.php/products_id/10/cPath/13_204/lichtmaschine-kaefer-u-co/lima-lichtmaschine-12v-kaefer-bus-porsche-30ps-typ1.html
http://www.beetle-factory-shop.de/product_info.php?info=p202269_Lichtmaschine-Gleichstrom-12-V---38-A.html
nice greetings
Marcel
« Reply #12 on: January 22, 2011, 13:00:47 pm »
lee i've some picture of pete's engine
i took those because i was thinking  doing the same for my engine
 Wink
« Reply #13 on: January 22, 2011, 15:55:30 pm »
 Wink
Well where are they then Huh Wink Wink Smiley
« Reply #14 on: January 22, 2011, 21:43:59 pm »
 Wink
in my archive  Grin Grin
« Reply #15 on: January 22, 2011, 21:58:22 pm »
just for you lee Wink
« Reply #16 on: January 22, 2011, 22:36:13 pm »
Nice and simple.
« Reply #17 on: January 23, 2011, 17:36:28 pm »
Fabs the paint on this engine tin is the same effect as the wrinkle paint you bought ?
« Reply #18 on: January 23, 2011, 19:32:29 pm »
Its very similar to the rattle can stuff BUT I know Ian/pete had it done by an old skool Ferrari guy - This stuff is ALOT more toxic  Shocked Wink
I think I'll be asking Ian to get me a few bits done for the Roller Crank Motor  Grin
Anyway back on topic - let have more info/pic's of 356 style dynamo's/Generators  Wink
« Reply #19 on: January 23, 2011, 21:34:22 pm »
So, are all 6v backing plates recessed, requiring the use of the narrow fan?
« Reply #20 on: January 23, 2011, 21:44:42 pm »
Thanks Lee  Wink
Peter Shattock
« Reply #21 on: January 23, 2011, 22:31:33 pm »
Lee,
Mine is a 25a version from a 356 mate of mine who had a spare. The backing plate is also from the same engine but the fan is a wide welded version in a CSP non dog house fanshroud. There was no drama fitting it although I may have just got lucky, but it was just a bolt on job and the fan belt lined and the fan fitted in the fanshroud a treat.
The crinkle powder coating is a really good job by a couple of really nice guys running a small firm in Farnborough North Camp, and I have no hesitation in recomending them, and it wasn't very much money either if you do all the prep and just give it to them ready to go. It seams to be hard wearing as well I've had the motor out 4 times this year trying to find a suitable clutch (3 of which were at the track) so its had a bit of a rough introduction to life in my car but its still looks in good shape. I'll dig out their number if your interested.
If you get one at it needs rebuilding or checking there is a good firm in Essex Phil West and I used to rebuild ours, again I'll dig out the number if your interested.
One other thing worth mentioning is the regulator, as I understand it can be difficult to get a regulator to suit the higher output generators. I know Lucas (55 oval OG paint and OG BRM's) has one on his and has had a problem with his regulator but Ian has something sorted now, but I'm not sure what or where from so you are best off speaking to him if you end up with one with a higher out put than the VW regulator. Just for the record the height out put generators are heavier than the 25A ones.
Peter Shattock
« Reply #22 on: January 23, 2011, 22:37:53 pm »
I forgot to say...... Fabs, the man with a photo for every occasion. Is there no end to the depths of his archive!
I kept meaning to take some pictures of the engine, but I needn't of worried.
Need a picture just call Fabs!
« Reply #23 on: January 23, 2011, 23:29:03 pm »
Cool Thanks for dropping in Pete  Grin
I was hoping there was a "simple" solution - I had kinda worked out it was the 25a one you need, I had also read about the regulator issues - I am gonna be using a Magneto so I am sure I will be fine with the 25a unit  Smiley
Better start looking/saving  Smiley
Pas
« Reply #24 on: January 24, 2011, 00:00:13 am »
Is this what your after ?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=350432766827&viewitem=&sspagename=STRK%3AMEWAX%3AIT
EDIT : Apologies Marcel (cel) just spotted that you have already posted this. Embarrassed
« Last Edit: January 24, 2011, 01:28:35 am by Pas » Logged
Pas
« Reply #25 on: January 24, 2011, 00:15:11 am »
Also from the same people.
http://cgi.ebay.com/ebaymotors/VW-Generator-12Volts-GR11X-Replacement-6Volt-_W0QQcmdZViewItemQQhashZitem41542daa1dQQitemZ280585153053QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Or with a Bosch regulator.
http://cgi.ebay.com/ebaymotors/VW-Generator-12Volts-GR11X-Replacement-6Volt-_W0QQcmdZViewItemQQhashZitem3cb16c2ffeQQitemZ260674695166QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Maybe some of you Cali guys have experience dealing with this company ?
« Last Edit: January 24, 2011, 00:40:37 am by Pas » Logged
« Reply #26 on: January 24, 2011, 01:30:40 am »
Yeah seen those and thats the type of Regulator I am trying to avoid - it looks SOOOOOOOOOOO wrong  Smiley
Plus I thought it was the GR26X model we are looking for  Undecided Smiley
Pas
« Reply #27 on: January 24, 2011, 02:05:50 am »
How about this then, think it is a GR26X or is it a 530 ? Undecided , check the price Shocked.
Might be worth checking with Pete if his dyno is a GR26X as there seems to be several Bosch model numbers for late 356/early 912 dyno's.
Agree with you about that regulator, not nice.
http://cgi.ebay.com/ebaymotors/Porsche-912-356-BOSCH-Generator-Small-90MM-Case-12Volt-_W0QQcmdZViewItemQQhashZitem3cadd5b4a9QQitemZ260614501545QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
« Last Edit: January 24, 2011, 03:43:03 am by Pas » Logged
« Reply #28 on: January 24, 2011, 16:11:17 pm »
 Cheesy Cheesy Cheesy thx peter
« Reply #29 on: January 24, 2011, 16:58:44 pm »
Unfortunetly thats the price of looking COOL  Wink
I am gonna have to look into this a little more,
Also Pete - could you please PM the contact details for the wrinkle finish guy - Cheers  Smiley
