September 23, 2026, 00:58:44 am
Fuel Pressure?
Topic: Fuel Pressure? (Read 5632 times)
Jesus
Fuel Pressure?
January 22, 2011, 16:40:35 pm »
Just curious really about what fuel pressures people are running on what spec of engine and on what carbs?
I am particularily curious about fuel pressures for 48 IDF's
Alex
PPRMicke
Re: Fuel Pressure?
January 22, 2011, 17:39:38 pm »
Quote from: Jesus on January 22, 2011, 16:40:35 pm
Alex
3.5 psi (max 4 psi )
//// Micke
Green Goblin
Re: Fuel Pressure?
January 22, 2011, 18:16:07 pm »
Hi Mate,
When the car was NA I was also using 3.5 PSI with 48 IDFs.
.....Now I run 4.5 and 9 PSI when on boost
www.DKRclub.co.uk
mick
Re: Fuel Pressure?
January 23, 2011, 09:21:05 am »
Similar question ! I have a carter fuel pump (cb) & 48ida s on a 2276cc
Not running a regulator ! how accurate does the pressure need to be ?
I suspect mine is a little high cos im having problems starting
Mick
Re: Fuel Pressure?
January 23, 2011, 11:24:58 am »
I run a cb pump on my 2276cc with IDA's with no regulator. The pump is set to run at
3.5psi so requires no regulating. If you are having problems starting I would think the problem is elsewhere.
Lee
Martin Greaves
10.88@128.58
Re: Fuel Pressure?
January 23, 2011, 13:10:55 pm »
Quote from: Green Goblin on January 22, 2011, 18:16:07 pm
Hi Mate,
No Andy you should have a 2 infront of that 9.
Jesus
Re: Fuel Pressure?
January 23, 2011, 16:40:42 pm »
Cheers for the responses
