September 23, 2026, 06:05:12 am
| | |-+  Hex head oil pressure and control relief plugs...washer or no?
Author Topic: Hex head oil pressure and control relief plugs...washer or no?  (Read 5167 times)
bugnut68
« on: January 25, 2011, 00:49:19 am »
I bought a pair of hex-key oil pressure relief and control plugs for my new engine build, but they didn't come with any washers...got 'em from CB Performance.  Do they go with a washer or no?
Ron Greiner
DKP II
« Reply #1 on: January 25, 2011, 01:30:28 am »
you definitly require the sealing washer between the plug and the case or else it will leak oil
it takes stock Vw units
stealth67vw
« Reply #2 on: January 25, 2011, 01:31:04 am »
Use the crush washer.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
bugnut68
« Reply #3 on: January 25, 2011, 02:06:27 am »
I figured that was probably the case.... Grrr.    Angry  It's a bit frustrating when I order parts such as this and don't get such rudimentary related hardware with them.  It's a good thing I had an Elring/German gasket set that included doghouse oil cooler seals, as the oil cooler I bought (and stand) had only the hardware to bolt it on/together, but no seals whatsoever.
If I still lived in an area where VW parts were available locally, I wouldn't be frustrated.  Wouldn't be an issue to tool on down and get what I need, but living here in rural southeastern Oregon it's a little less than pleasing to buy parts and not have such basic hardware with them.  Shipping is a bit pricey for such lightweight and rudimentary hardware.
I'm fairly certain that the gasket set didn't have these crush washers included.  Looks like I'm not done mail ordering parts yet.  Roll Eyes
bugnut68
« Reply #4 on: January 25, 2011, 02:24:42 am »
Anybody have a VW part number for that washer?  I could not find any in my gasket set at last check, and need to hunt a pair down.
The oil gallery temperature sending unit I got for my temp gauge also came with nothing... Huh  I don't understand why these parts don't come with the needed hardware for installation.  It would be like selling oil change gasket sets with only gaskets and no copper washers...lol.  Maybe not the best analogy, but it's the best I could do on the spot. Grin
« Last Edit: January 25, 2011, 17:59:12 pm by bugnut68 » Logged
bugnut68
« Reply #5 on: January 25, 2011, 19:15:19 pm »
Think I've tracked down what I need, now to find out if I can get it locally.  Lol.
Found this, also: http://www.pacificcustoms.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PC&Product_Code=AC101015&Category_Code=
Looks like I should have done a bit more research... apparently there ARE vendors out there who outfit their parts with all the needed hardware.  Roll Eyes  Good to know for the future.
Question, though, do I use the same type of crush washer for an oil gallery temperature sending unit, or should I use a different type of washer?
« Last Edit: January 25, 2011, 19:17:25 pm by bugnut68 » Logged
Gary Justus
« Reply #6 on: January 25, 2011, 19:24:43 pm »
^^^^^^^^Just so you know. Those would be EMPI.
bugnut68
« Reply #7 on: January 25, 2011, 19:33:24 pm »
Irony...lol.  I may be lucky in this instance, and may be able to purchase the crush washers locally at the limited hardware resources I have here in this tiny cow town I call home.  I'm going to start working on stocking up needed hardware/seals/yada/yada/yada for future engine builds so I will always have a quantity of some of these items on hand for future engine builds.
I  just came to realize recently that there are two different engine gasket sets available, one of which has the main seal included... live and learn!  Apparently, I was NOT crazy in thinking that such a thing existed. Grin
