September 23, 2026, 07:17:39 am
Can you stack valve spring shims if necessary?
Topic: Can you stack valve spring shims if necessary? (Read 3237 times)
Brandon Sinclair
January 25, 2011, 19:42:39 pm »
I have valve spring shims of .015" .030" and .060". Do they make thicker ones or if I need a larger size is it ok to stack them?
The Action Is Go
Re: Can you stack valve spring shims if necessary?
January 25, 2011, 20:00:09 pm »
Yes, you can stack, and they make different thicknesses for correct geometry.
