October 14, 2026, 01:05:14 am
| | |-+  Dishing pistons
Author Topic: Dishing pistons  (Read 6972 times)
« on: January 27, 2011, 20:35:31 pm »
Hello guys,
to lower the CR for the turbo i would like to dish my wiseco pistons.
11 cc would be the max..
i found out that a dish of 84 mm and 2 mm deep would give me that.
so there would be an edge of 5 mm.
Does this sound ok?
thanks
« Reply #1 on: January 27, 2011, 21:23:51 pm »
I don't know about your pistons, but this should help a little:
http://cal-look.no/lounge/index.php/topic,6664.0.html
« Reply #2 on: January 28, 2011, 08:28:17 am »
In the pictures below you can see the dish in my Wiseco pistons - 11cc:
Best rgs
BB
K-Roc
« Reply #3 on: January 30, 2011, 01:10:38 am »
I was going to dish some Weisco's and was thinking that it would be better to mirror the chamber shape in the piston as this would keep the Flat areas of the piston and the chamber ( the squish band ) at my .040" deck... My thinking is that keeping a tight squish band  helps reduce the chance of detonation.
You guys have any thoughts on this?
Darren
ED2.4
« Reply #4 on: January 30, 2011, 10:49:23 am »
Darren
+1, i try to keep the chamber shape too for the dish,better squish  as you say ,
here's a good example :
http://www.lnengineering.com/type1.html
DeluxeRacingTeam >>>>  http://charlie48ida.skynetblogs.be/
« Reply #5 on: January 30, 2011, 12:30:26 pm »
Thanks for the reply guys,
i would like to mirror the dishes,
but that way, i wont be able to drop the CR enough..
ED2.4
« Reply #6 on: January 31, 2011, 19:01:43 pm »
yes and no, because the dish is wider than 84 mm on the ends ,
so   it must  compensate a bit ,
 nice for a N/A engine ,but on a turbo i would not go  closer from the edge/first ring than 5mm
« Reply #7 on: January 31, 2011, 20:48:36 pm »
thanks guys,
well i have a new solution;
a guy i know can drop off the heads in germany to cnc the chambers..
he thinks i will be able to get 10 cc more out of them Smiley
