September 22, 2026, 11:51:46 am
| | |-+  GAS BURNER WHEEL REFURB
Author Topic: GAS BURNER WHEEL REFURB  (Read 10695 times)
Straight Time
« on: April 05, 2007, 11:47:20 am »
Hi , anyone ever restored a set of origional Gas burner wheels ? Need some advice. Looking to get them back to standard finish.
What is best to strip old paint off ?  Nitromors or is this too harsh ?
Would you advise painting the back of the rim and the inside ?
What type of paint to get that OG Finish ?
I also have a Porsche space saver wheel  which is 5.5j x 15, ET 33. Anyone know if this is the same stud patern as the gasburners. It does have 5 bolt holes ?
One last thing, need a set of center caps .... Anyone have some for sale or know who sells them for the burners .
Many thanks guys. Wink
No retreat, No surrender !
El Diablo Gris
« Reply #1 on: April 05, 2007, 15:14:16 pm »
I've done a few sets, and the SAFE way to strip them is media blasting (walnut shell or baking soda).  Many chemicals have bad reactions with magnesium, and will distort or eat at the wheel.
If you only want to do this one time (hint) , primer and paint the entire wheel to completely seal it.  If you don't, the mag will gas-off and you will have bubbles and holes that will start to form under the paint after time, especially in damp climates.
The wheels were originally a semi-gloss silver that Porsche has in their color charts from 1971.  Many powdercoaters have similar colors.
Your space saver should be a 5 X 130mm pattern too.
The center caps are the early Porsche 3-prong style, just like the Fuchs use.  They are listed on e-bay all the time, or new ones at www.performanceproducts.com under Porsche parts.
Hope this helps, good luck !
Darrell
Rocket Ron
It's old school for a reason
« Reply #2 on: April 05, 2007, 16:23:33 pm »
I think Flat 4 do some chrome / polished tye that fit
 Cool
13.12 @ 101.84
Grooving out on life
Straight Time
« Reply #3 on: April 05, 2007, 16:52:50 pm »
Thanks for all the advise . Your right, do only want to do them once. All the best. Cool
48IDA66
« Reply #4 on: April 05, 2007, 19:54:16 pm »
I have mine blastet, then polised and finaly paint semi gloss paint, I also paint the inner(back) all black.
After a month they look dull, and to keep them bright is impossible, but I can live with that.....
« Last Edit: April 05, 2007, 20:25:43 pm by 48IDA66 » Logged
Straight Time
« Reply #5 on: April 05, 2007, 21:02:41 pm »
wow !!!! they look great  Shocked Hope mine turn out like that though i know the shine wont last. Nothing wrong with patina !!
JS
« Reply #6 on: April 06, 2007, 00:13:40 am »
I actually think the "semi-bright" finish is very cool.
Signature.
