October 02, 2026, 14:54:19 pm
4 lug Empi Sprintstars Repro's,Are they Cal look?
Topic: 4 lug Empi Sprintstars Repro's,Are they Cal look? (Read 20852 times)
drgouk
January 29, 2011, 04:41:53 am »
4 lug Empi Sprintstars ,Thinking of a set of 4 lug empi sprint stars for my 65 bug, it has a 98 mexican pan converted to irs. What do you guys think?
Any pics of 4 lug sprintstars on a early car would be great. Thanks David
Re: 4 lug Empi Sprintstars Repro's,Are they Cal look?
January 29, 2011, 06:24:18 am »
I think the repro's machined aluminium finish looks like shit, personally. And they have a crummy offset. Real EMPI wheels can be found easily and are still affordable. Also, real wheels can be had in staggered sizes, like 4.5" & 5.5". As far as fitting them to an early beetle, I say go for it!
neil68
January 29, 2011, 06:28:16 am »
Check out the Sprintstar Registry website for some photos:
http://sprintstar.blogspot.com/
Are they Cal-Look? Here's my Cal-Looker with original '68 EMPI Lemmerz Sprintstars:
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
drgouk
January 29, 2011, 09:43:48 am »
Thanks Guys, Il see what I can round up.
tuna
January 29, 2011, 19:19:31 pm »
As far as I'm concerned, they are Cal-Look, but I'm a little biased.
My '69 Cal-Looker has 4-lug Sprint Stars.
The original Sprint Stars were available in 4.5", 5.5", 8", and 10" widths. The 4.5"s fit fine on an IRS car, but I found the offset of the 5.5" placed the 185/70R15s too far outside of the rear fender for my tastes. One inch of the tire was outside of the fender. That's why I'm having another pair of Sprint Stars set up with 6" bands and with an offset that better suits my car.
Tuna
My VWs -
http://tunacan.org/cars/
Type 4: Secrets Revealed -
http://tunacan.net/t4/
EMPI Imp Homepage -
http://tunacan.net/imp/
Tom's Type 4 Corner -
http://tunacan.net/t4corner/
drgouk
January 29, 2011, 19:45:36 pm »
Quote from: tuna on January 29, 2011, 19:19:31 pm
Tuna
Thanks for the usefull info. So you cut the centres out and are having them welded in so new 6"rims? sounds like a good idea.
January 29, 2011, 20:13:01 pm »
That's the easy (smart) way to do it since the 5.5's have a good bit of offset. When I added rear discs to my car it pushed the 165's out way too much for my liking. I didn't want to change the look of the wheel, so I had the trailing arms narrowed 26mm on each side. This put them right back where they needed to be.
drgouk
January 29, 2011, 23:45:00 pm »
Quote from: Zach Gomulka on January 29, 2011, 20:13:01 pm
Cool bit of empi history there Zack. Any pics of the wheels straight on? I am thinking some genuine empi wheels would give my car a empi theme, along with my genuine empi gtv steering wheel. The car has a 2.8 pauter engine,like dons ghia, for the street. So it should be unique. I have 99% of the engine parts, Just waiting on pistons and cylinders.
This is the pan, doing a dummy up before powdercoating.
January 29, 2011, 23:49:09 pm »
Here's an old cell phone shot, pre narrowed arms, pre a lot of things!
drgouk
January 30, 2011, 04:29:48 am »
Zack, are they 4.5"s on the front? dropped spindles? narrowed beam? Thanks
January 30, 2011, 04:49:36 am »
Stock beam, I only added drop spindles. 145's on 4.5's and 165's on 5.5's
drgouk
January 30, 2011, 04:51:26 am »
Zack,No rubbing issues on the front guards?
Last Edit: January 30, 2011, 06:48:48 am by drgouk
drgouk
January 30, 2011, 06:47:59 am »
Quote from: neil68 on January 29, 2011, 06:28:16 am
Hi Neil,
What size combo are you running? Narrowed front beam, dropped spindles etc? at the rear, long or short axle or irs? Tyre sizing? Thanks. David
neil68
January 30, 2011, 17:26:05 pm »
For that photo: 4.5" Sprintstars front and back, stock long swing axle, CB dropped spindles on stock beam, stock rear height, 145R15 Nankangs front and 195 Dunlops rear.
Now running:
Front: 4.5" wheels, stock beam, CB dropped spindles, 145R15 Nankangs
Rear: 5.5" wheels, short swing axle, 215/15 M&H (just barely fits under the fenders).
Neil
Dynojet Test:
fredy66
January 30, 2011, 17:47:20 pm »
front 4.5 adjustable beam 145
back 5.5 stock 165
arabia slugs
January 30, 2011, 19:15:22 pm »
Quote from: drgouk on January 30, 2011, 04:51:26 am
With the stock sway bar there was enough body roll to make the tires rub in hard turns. I put on a 3/4" bar and that fixed it- unless I have passengers and I really try and corner hard. I'm hoping a rear sway bar will solve it entirely.
January 30, 2011, 19:16:48 pm »
I think so.
145's front on 4.5's dropped spindles.
185/60's on 5.5 rears
plasticblack
January 30, 2011, 19:22:13 pm »
I don't like the new Sprintstar replicas. The profile and finish just looks wrong.
Like people have already said, there are enough of the real thing around, so why have poor looking repo's..
This is a pic of my friends Bug. I'ts loaded with cool items and the Sprintstars are really nice looking..
fredy66
January 30, 2011, 19:25:25 pm »
Quote from: plasticblack on January 30, 2011, 19:22:13 pm
cool
arabia slugs
plasticblack
January 30, 2011, 19:26:37 pm »
Quote from: fredy66 on January 30, 2011, 19:25:25 pm
Isn't it..
cool
January 30, 2011, 19:27:55 pm »
now where is the key!!!! Lets see that pic.
drgouk
January 30, 2011, 20:36:41 pm »
Thanks for the info and pics guys.
plasticblack
January 30, 2011, 20:46:09 pm »
Quote from: Lids on January 30, 2011, 19:27:55 pm
Did you lose your key
January 30, 2011, 22:22:11 pm »
Always liked Deans car
January 30, 2011, 22:24:11 pm »
Needs 4.5's up front
