October 13, 2026, 21:30:04 pm
| | |-+  Best way to wire in an electric fuel pump?
Author Topic: Best way to wire in an electric fuel pump?  (Read 5885 times)
« on: January 29, 2011, 23:33:55 pm »
I run a CB Performance rotary 3.5 psi fuel pump. I currently have it wired in from the master cylinder brake light switch
but I have never been 100% happy with this (rush job)
I would like to hear how you guys wired them in, I have heard of using a relay? A toggle switch to turn it on?
Any ideas appreciated!! Smiley
drgouk
« Reply #1 on: January 29, 2011, 23:47:57 pm »
A relay trigered by the ignition switch would be my choice.
« Reply #2 on: January 30, 2011, 00:43:29 am »
Thanks for the reply. How would I wire this set up? Any wiring diagrams out there?
« Reply #3 on: January 30, 2011, 07:06:29 am »
mine is wired to the ignition switch, it comes on when the key is turned, and could be an issue in an accident.  But this is how the wiring diagram said.
Jesse/DVK
'64 2176cc
« Reply #4 on: January 30, 2011, 10:52:00 am »
I have it wired with a flip switch on my dashboard.
vintagewagenwerks
« Reply #5 on: January 31, 2011, 23:09:02 pm »
my pump is switched by ignition .wired form the coil kl.15 to pump and ground of course .Switched by a master switch indepandent from the turn key.
Itīs better to burn out than to fade away.
kevinlvy
« Reply #6 on: February 01, 2011, 00:46:21 am »
love to see the picture of each set up if possible so that we can have it for future reference.  Grin
« Reply #7 on: February 01, 2011, 07:16:37 am »
Why not wire it so that it stop pumping if the oil pressure drop under a certain level? Even better if you also combine it with a relay that also stop the engine so that it does not continue to run as long as there is fuel in the carbs.
