September 22, 2026, 19:38:13 pm
Valve angle in CB competition eliminators
Topic: Valve angle in CB competition eliminators (Read 5953 times)
Tobi/DFL
February 04, 2011, 10:02:39 am »
Hi!
I want to cut valve pockets in my pistons. Does anybody know the correct angle of the valves in a CB competition eliminator head?
Thanks!
Tobi
Last Edit: February 04, 2011, 15:31:06 pm by Tobi/DFL
dangerous
Re: Valve angle in CB competition eliminators
February 04, 2011, 22:16:00 pm »
Always double check YOUR valve location and angle,
but it should be close to 9 degrees.
February 05, 2011, 01:40:23 am »
I thought T1s used an 8* valve angle, or was that for the T2/4?
Martin
Cash Converter....
February 05, 2011, 08:17:20 am »
last set i measured were 9.5 deg
Martin
www.taylormachine.co.uk
OFF/500
Tobi/DFL
February 05, 2011, 10:47:13 am »
Thanks everybody!
I measured mine with just a little more than 9 degrees so that should be right.
Now the fun part begins...
Tobi
Type1/DVK
February 05, 2011, 16:28:25 pm »
and anyone that knows the original or 044 heads? the same? thanks
DDD#8 - 14.74sec @ 1776cc - Member of: DVK ~ Der Vollgas Kreuzers -
www.ultimatevw.nl
- and racing engines
Roman
February 05, 2011, 17:51:55 pm »
The stock, 041 and 044 heads has 9.5 degrees (or as it says in the stock manual, 9 degrees 30 minutes).
