October 13, 2026, 10:21:02 am
Waterboxer,WBX, 36 tooth EFI pulley
Topic: Waterboxer,WBX, 36 tooth EFI pulley (Read 3333 times)
m.m.p
February 10, 2011, 01:53:29 am »
ive done a limited run of waterboxer pulleys with 36 teeth for running your crank trigger for your EFI system
it clears the waterpump pulley and are 36 teeth so you can mount the sensor anywhere you like then remove the tooth were you need to.
£80 out right or £60 if you give me your wbx pully to work on.
thanks
Marco Mansi
Last Edit: February 10, 2011, 02:15:53 am by m.m.p
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
m.m.p
Re: Waterboxer,WBX, 36 tooth EFI pulley
February 10, 2011, 02:16:31 am »
Marco Mansi
0044(0)7947 660 924
February 14, 2011, 00:14:21 am »
