September 22, 2026, 01:30:36 am
| | |-+  Cleaning a Hot Coat Header..?
Author Topic: Cleaning a Hot Coat Header..?  (Read 6004 times)
Kaferdog
« on: February 14, 2011, 05:50:40 am »
Anyone have any neat tricks to cleaning burned oil on silver ceramic hot coat finish without hurting it ...?...I've heard " Oven cleaner" and "Scotchbrite"...but that seems harsh....Huh
Bobby Welker
« Reply #1 on: February 14, 2011, 06:06:36 am »
hey you could try 0000 steel wool and rubbing alcohol that usually works on mine .  Hope this helps you out.
John Rayburn
« Reply #2 on: February 14, 2011, 06:37:25 am »
Mothers Mag Polish.
I also park at Nick's.
Kaferdog
« Reply #3 on: February 14, 2011, 06:46:34 am »
Thanks guyz..I will try it both
« Reply #4 on: February 14, 2011, 07:21:58 am »
Theres always Coke and a rag.  Roll Eyes  Wink
Kaferdog
« Reply #5 on: February 14, 2011, 09:27:01 am »
Regular or Diet....Huh?...LOL.... Cheesy
Dominick Luppino
« Reply #6 on: February 14, 2011, 16:27:28 pm »
I use Turtle Wax Chrome polish or Never Dull.
« Reply #7 on: February 14, 2011, 16:30:24 pm »
I have been using aerosol carb cleaner and scotch brite pad to clean burned on stuff for years.  After cleaning I use a metal polish to return the original luster.
Kaferdog
« Reply #8 on: February 14, 2011, 20:24:55 pm »
Wow .. Shocked....such a wide variety of ideas....I never would have guessed these...!...But metal polishers seem to be the basic idea...kinda makes sense
« Last Edit: February 15, 2011, 11:23:46 am by Kaferdog » Logged
Speed-Randy
« Reply #9 on: February 14, 2011, 23:04:30 pm »
Hotsy pressure washer cranked up to 200 degrees takes all old oil coating off and leaves it looking like new
Cheesepanzer
« Reply #10 on: February 15, 2011, 02:44:36 am »
I've used SOS pads on tough oil stains with good results.   Never tried to polish it afterwards - will do that next time.   Tongue
63 Type 2 Single Cab
Cornpanzers
