September 23, 2026, 00:30:54 am
Freezing components.
Topic: Freezing components. (Read 18372 times)
April 11, 2007, 13:35:20 pm »
Has anybody else tried/heard of this?
I was reading an article last night about the subject and it was very interesting, just wondering if it's as good as they're claiming
Last Edit: April 11, 2007, 14:02:29 pm by TRAMP
Alan Uyeno
Re: Freezing components.
April 11, 2007, 15:56:27 pm »
cryoing isn't an expensive process and it appears to help. Is it a solution to pitting lifters??? NOPE. I got my gears in my trans cryoed. I think its a piece of mind more than anything but people have had excellent success doing it.
Frank LUX
Back...Soon...hopefully!!!
April 11, 2007, 16:22:31 pm »
I heard about that too...
I was told that it is very helpfull on R&P....
Frank
ESH
April 11, 2007, 20:14:53 pm »
I heard of a lawnmower that made 3 more HP after a little cryo, percentage wise that's a good hike!
April 11, 2007, 20:54:19 pm »
Quote from: Alan Uyeno on April 11, 2007, 15:56:27 pm
Yeh.
After going through it again, they're saying that some formula 1 teams use it for their engines.
If it's good enough for formula 1, it's good enough for VW's.
Also saying that they could do an engine for £400, no bad i thought.
April 12, 2007, 01:06:50 am »
can someone help me here
why would you want to freeze an engine
whats the theroy
just some more info would be cool
ESH
April 12, 2007, 09:01:21 am »
Put simply and according to my limited understanding of it cryogenic freezing of certain metals changes the structure of the material improving certain charecteristics. It's a few degrees on from simply freezing it so sticking it in your freezer won't work! There are several components that potentially benefit from the process.
April 12, 2007, 12:53:46 pm »
Quote from: monkiboy on April 12, 2007, 01:06:50 am
whats the theroy
The article i read was in
MAX POWER
April 12, 2007, 21:49:10 pm »
Quote from: Mat Sanchez on April 12, 2007, 09:01:21 am
Thanks dude now I understand - I better get the 1641 out of my mum's freezer then
April 13, 2007, 03:28:32 am »
I have tried a few different things,the most success I have had is with valve springs,got 3 years now on my K800s with a very small lose in pressure,just for reference a non cryoed set lost more pressure in the spring pressure measuring tool after to checks than mine have after the 3 years running,cheers richie,uk
quickkafer
German-Pride.com
April 19, 2007, 21:34:11 pm »
I'm no expert on this process either, but what I have read about it did not state that it will make your engine produce more power. I think that is a myth. The process causes the molecular structure to align itself into a more uniform pattern. I believe that it requires a freeze and thaw cycle several times over to achieve the results that are described. When all the molecular structure is uniform, there is less opportunity for breakage since there are no defects (or weak points) in the part.
The parts aren't changed in shape or size in anyway, so I'm not sure how more horsepower could be gained from the cryogenic process. If you've got a link that shows how HP gains have been made by doing this, I would love to read it. But it is my understanding that strength is the only thing to be gained.
Scott Faivre
www.german-pride.com
An
INTERNATIONAL
VW Community
66 Sedan & 64 Kabrio
Come see what's going on around the VW world!
April 20, 2007, 00:10:26 am »
mmmm interesting
ESH
April 20, 2007, 09:40:58 am »
Quote from: quickkafer on April 19, 2007, 21:34:11 pm
...The process causes the molecular structure to align itself into a more uniform pattern...
...The parts aren't changed in shape or size in anyway, so I'm not sure how more horsepower could be gained from the cryogenic process...
Depends which components you are talking about but the change at a molecular level can improve cooling in certain components by increasing the rate at which heat is dissipated and this can have a moderate effect in the ability to make consistent power. For data to confirm this you'd have to experiment a little but it would probably be worthwhile.
quickkafer
German-Pride.com
April 20, 2007, 17:39:53 pm »
Yeah, but I think the real deal is that after you've made the parts stronger, you can push them a little harder to squeak out more horsepower. It's the tuning done afterward that creates more power, not just freezing the parts and putting them back the same way they were before. The material that the part was made from hasn't changed (For instance: Aluminum into some ultra-rare alloy), so the thermodynamic characteristics of the material won't really be changed at all. I could be wrong. Like you said, there's only 1 way to find out.
Cryo'ing parts for the increase in stregnth is why we should look into this treatment. If we generate a miniscule more amount of HP that's just an added bonus!
Scott Faivre
An
INTERNATIONAL
VW Community
April 22, 2007, 02:38:03 am »
This is a very interesting thread - I am going to research this ALOT for my next engine
So which components are normally frozen
Frank LUX
April 22, 2007, 12:09:55 pm »
Quote from: monkiboy on April 22, 2007, 02:38:03 am
I would go for Heads and R&P...
Frank
April 22, 2007, 12:24:39 pm »
I take it R&P stands for rods and pistons
thanks for the info though dude
Frank LUX
April 22, 2007, 12:45:06 pm »
Quote from: monkiboy on April 22, 2007, 12:24:39 pm
No, it stands for Ring and Pinion, you know the thing that always lets go in the Race Trannies...
Frank
April 22, 2007, 13:35:53 pm »
yeah I realised that after I posted that
but what about rods
Frank LUX
April 22, 2007, 14:44:25 pm »
Quote from: monkiboy on April 22, 2007, 13:35:53 pm
but what about rods
Don't know, i have not used that "freezing" process yet, but will probably let my heads get Cryod next Time...
Frank
quickkafer
German-Pride.com
April 22, 2007, 19:25:26 pm »
I don't think it would hurt to get any of your parts cryo'ed. But usually it's the high stress items first. (i.e. cranks, cams, rods, flywheel, etc.) basically anything that stands a chance of shearing from repeated abuse.
Scott Faivre
An
INTERNATIONAL
VW Community
April 23, 2007, 22:35:39 pm »
I know Bruce Tweddle cryod my ZF diff before I bought it. And the rest of the car gets cryod every single winter!
Chris W
May 01, 2007, 22:12:37 pm »
I listend to this a while back. It has some good info I thought.
http://richchristensen.com/radio/ivdimension.php
Click on
Cryogenics
under broadcasts.
