September 22, 2026, 12:00:42 pm
| | |-+  bolt-on sand seal install how to?
Author Topic: bolt-on sand seal install how to?  (Read 16794 times)
bugnut68
« on: February 14, 2011, 20:30:49 pm »
I've got a spare degree pulley with sand seal (bolt-on) sitting in my garage... how do you install the sand seal, do you just place it in there and bolt the pulley on or do you use some sort of sealant with it?  Just curious, never used one before, and it's practically brand new.
Dave Rosique
nobodyouno
« Reply #1 on: February 14, 2011, 21:17:35 pm »
Personally, I've never liked sand seals.
I've used and installed plenty over the years but never by choice.
Oh wait.. did you ask my opinion? Grin
bugnut68
« Reply #2 on: February 14, 2011, 21:27:53 pm »
Well, it's like this...lol.  I've never used one before, but I happen to have it sitting in my garage.  I'm currently awaiting an exchange on the billet CB Performance pulley I bought that didn't fit my crank (a cursory measurement indicated it was about .002" smaller on the OD than another pulley I have that DID fit), was looking at the sand seal pulley and wondered how installation was done.
Dave Rosique
nobodyouno
« Reply #3 on: February 14, 2011, 22:27:20 pm »
OK, I get it.
If you have to use it (please reconsider) it would be worthwhile to use sealant between the seal adapter and case. I used to use a Loctite product (not red threadlocker).. sorry, don't recall the product number right now.
After adapter install, press the seal clean and dry in to the adapter then lightly grease where the seal rides on the pulley before install.
No kidding, sand seals tend to leak--especially the no machine work needed type you have.
Of course, some people may like 'em.. that's cool too..
« Reply #4 on: February 14, 2011, 22:33:56 pm »
Easy:
Dave Rosique
nobodyouno
« Reply #5 on: February 14, 2011, 22:44:54 pm »
True BB,
But I thought we were talking about a no-machine sand seal like the one pictured with collar (adapter)
bugnut68
« Reply #6 on: February 14, 2011, 22:57:36 pm »
True BB,
Yep, that's what I have, what Dave showed above...
« Reply #7 on: February 14, 2011, 23:06:09 pm »
Mine was also "bolt on" and no mods needed.
dragvw2180
« Reply #8 on: February 15, 2011, 00:59:04 am »
  Loosen the bolts above and below the seal opening in the case, I used aircraft sealant on the adapter to block mating surface, you only need a small amount. The adaptor should slide in with your fingers, then retorque your bolts. I have used them on multiple motors ( turbo) and have had good luck with them.I hate an oil leak,       Mike
« Reply #9 on: February 15, 2011, 01:13:19 am »
we would sometimes Devcon them in.
bugnut68
« Reply #10 on: February 15, 2011, 01:14:38 am »
I may use it on another engine project... I will work through this deal with CB and see where i'm at then.  This is the first time I ever bought a pulley that didn't fit a crankshaft... very strange, but I guess there's a first time for everything.
Dave Rosique
nobodyouno
« Reply #11 on: February 15, 2011, 02:14:54 am »
Sounds like a plan.
As I said, some guys like sand seals.. that's fine with me.
j-dub
« Reply #12 on: February 15, 2011, 02:55:39 am »
I have one that I am considering as well. My question is what sealant to use. My "bolt in" seal slides in loose enough that i can spin it when I was test fitting it.
Any advice on what type of sealant to stick this thing in there would be appreciated.
Jeremy
bugnut68
« Reply #13 on: February 15, 2011, 02:59:07 am »
Jeremy
That's kind of what I noticed about mine.  It doesn't necessarily spin in there that I can tell, but it slips right in.  I have another long block in my garage that has one all gooped up with some orange stuff.
j-dub
« Reply #14 on: February 15, 2011, 03:15:17 am »
I was recommended to use this at one time, have not tried it yet.
« Reply #15 on: February 15, 2011, 13:23:54 pm »
I'm considering a machine-fit one to rescue a case that has maybe 3 seasons limited race use on it and spat off a pulley, taking out the end of the case. I'm hoping that the machining will cut out all the damage. Anyone have any pictures of the machining needed?
dragvw2180
« Reply #16 on: February 16, 2011, 15:23:16 pm »
   When I installed one in my Speedster the case was used and the hole for the pulley in the case was a loose fit. Like the one you posted , I could actually turn the seal adapter in the case. I cleaned the surface with brake clean and used JB WELD , an epoxy, and never had a problem with it. If you look at the picture you can see why I used a seal.      Mike
j-dub
« Reply #17 on: February 27, 2011, 02:12:17 am »
I just installed one and I used super weather strip adhesive to glue it in. I have very limited run time on it, but so far so good.
