July 01, 2026, 18:52:23 pm
Latest Member: bigsiembowski
| | |-+  re: a '66 horn steering wheel exploded view
Author Topic: re: a '66 horn steering wheel exploded view  (Read 3549 times)
« on: February 15, 2011, 06:37:50 am »
Got a '66 steering column in my '56 and I thought I put the Horn / contact assembly back together correctly -- but there isn't very much play in the horn button assembly
and all the views I found just aren't that clear
« Reply #1 on: February 15, 2011, 14:58:14 pm »
i 've the old column (oval one) on my 61 and goes to an 65 formy empi steering wheels ,
here's what i've used to wiring correctly my horn, and it works
 the one on the top is oval wiring and the one below is the one i used
« Reply #2 on: February 15, 2011, 15:47:55 pm »
I've probably mis-discribed my problem -- it is in the area of steering wheel and how the horn ring attaches to it -- I went down to wolfberg west and bought one of those $5 horn contact kits (113998225) that have the 3 new screws and the springs and plastic washers and it just doesn't allow much movement of the horn ring
« Last Edit: February 15, 2011, 16:21:07 pm by Fiatdude » Logged
Wünderwolff
aka Dr. Jeckill
« Reply #3 on: February 16, 2011, 07:58:04 am »
No it doesn't, I have been puzzling on the original ones for quite some time as well. But when you look at it, it doesn't need a lot of movement, it's either honk or not.
I can't remember exactly, but if I'm not mistaken, there are some plastic washers as well, to isolate the horn ring from the steering wheel. I'll check if I can dig the steering wheel out and if it is complete enough to take pictures of.
Wünderwaffe are Go!
