September 25, 2026, 02:38:49 am
52mm throttle bodies
Topic: 52mm throttle bodies (Read 5976 times)
m.m.p
February 15, 2011, 17:12:11 pm »
I am selling my 52mm Pro Race Mikuni throttle bodies, with fuel rails and CB comp eliminator IDA manifolds(unported)
These are custom designed by me (Marco Mansi), the throttle bodies are a single Mikuni body joined up to a second one, The bodies are set up with custom IDA Cb performance comp eliminator manifolds as the whole setup was designed to look like IDA's, there designed to take a cable linkage.
They come with fuel rails and there are 8 X 220cc Injectors. Also included is two quick release fuel unions, two throttle position sensors, two fuel presure regulators and 4 polished one off stacks.
They are 48mm at the bottom, 55mm at the top of the throttle body , 65mm at the top of the trumpet, have a 52mm throttle plate, the system has a continuous taper from top to bottom, this increases air speed to the motor = more power, comes with 8 injectors (two per cylinder with a fine mist spray pattern),there is enough fuel injector for over 300hp and there 1/3 lighter than Ida's
These are real one off's but using commonly available parts
Price is £750 and i can ship worldwide
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
m.m.p
Re: 52mm throttle bodies
February 15, 2011, 17:13:27 pm »
Marco Mansi
0044(0)7947 660 924
m.m.p
February 15, 2011, 17:17:08 pm »
Marco Mansi
0044(0)7947 660 924
m.m.p
February 15, 2011, 17:18:17 pm »
Marco Mansi
0044(0)7947 660 924
yvre
Der Autobahn Scrapers
February 16, 2011, 23:40:39 pm »
Nice pieces.
OT: Do you use 2 fuel pressure regulators?
m.m.p
February 16, 2011, 23:53:45 pm »
Yes you can, it makes no difference
Marco Mansi
Marco Mansi
0044(0)7947 660 924
m.m.p
February 17, 2011, 21:42:23 pm »
These throttle bodies would be perfect for a large T1 or oxyboxer running 4in bore( 2332 and up!!) they can also be fliped around so the injectors are on the inside perfect for street or strip, would be perfect for a big power bus running the JPM heads
Marco Mansi
0044(0)7947 660 924
m.m.p
March 05, 2011, 20:06:22 pm »
Still for sale
Marco Mansi
0044(0)7947 660 924
m.m.p
March 08, 2011, 20:44:00 pm »
pending
Marco Mansi
0044(0)7947 660 924
