October 14, 2026, 02:41:54 am
| | |-+  Hurst roll control adapters
Author Topic: Hurst roll control adapters  (Read 6935 times)
Pas
« on: February 19, 2011, 00:06:01 am »
This has probably been asked before, but does anyone know of a UK stockist of Hurst roll control (line lock) adaptors that allow you to use 10mm x 1mm VW brake line nuts ? I know Heritage sell them but are currently out of stock.
FDK/mrpedrini
« Reply #1 on: February 19, 2011, 18:26:05 pm »
Hi! Try Speedflow in the U.K. They sell lots of adapters... I live in holland and got mine from Paruzzi ... they sell them as adaptors for Tarox brake calipers, but can be used in Line-Lock aplications. Good Luck
« Reply #2 on: February 19, 2011, 18:49:45 pm »
X2
Black Sheep
less is more
« Reply #3 on: February 19, 2011, 19:24:33 pm »
Drop Bernie a line he may a few still knocking about  Wink
13.03 @ 98mph
kev d
« Reply #4 on: February 19, 2011, 19:31:38 pm »
Also CSP Cool
« Reply #5 on: February 19, 2011, 20:47:58 pm »
vw heritage
Pas
« Reply #6 on: February 20, 2011, 22:40:08 pm »
Thanks for your input Guys, I will get onto it tomorrow.
Taylor
« Reply #7 on: February 21, 2011, 03:00:15 am »
you are better off not using adapters.   buy some American brake lines, cut one end off, bend/shape to fit and put the vw line nut on and flare it out.  Both use 3/16 line less adapters means less chance off leaks.
Pas
« Reply #8 on: February 21, 2011, 10:08:40 am »
That's interesting, I thought that you needed an adapter fitting for all brake lines as the ports on the line lock are just straight threaded holes with, as far as I can see, nothing for the flared brake pipe end to seal against.  Are American brake line ends formed differently?
Jim Smith
« Reply #9 on: February 21, 2011, 18:22:19 pm »
Hi Pas, if you still are having trouble getting hold of some , give me a call at the workshop tomorrow 01242 232084 should be able to sort you some.
www.cotsweld.co.uk      Race car fab   01242 232084
Steve G
« Reply #10 on: February 21, 2011, 19:08:06 pm »
Could you sort some out for me too Jim?
I need three of them to fit a proper valve in place of the manual one on the multi coloured car.
I'll give you a ring tomorrow, if I remember.
Pas
« Reply #11 on: February 21, 2011, 19:34:32 pm »
Cheers Jim will give you a call tomorrow.
Jim Smith
« Reply #12 on: February 21, 2011, 21:00:32 pm »
No probs at all, just give me a call.
Steve G
« Reply #13 on: March 01, 2011, 20:40:36 pm »
I know it doesn't allow you to use the original male fittings, but I've come up with a solution that's going to work for me, after speaking with Jim at cotsweld and slightly tweaking his idea.
I'm using 1/8NPT to M10x1.0 male adapters and M10x1.0 female 3/16" pipe connectors, with a single flare on the end of the pipe.
Got 3 of each from Rally Design for £11.05 delivered.
