September 21, 2026, 23:07:36 pm
| | |-+  notch intercooled
Author Topic: notch intercooled  (Read 13401 times)
« on: February 22, 2011, 09:18:28 am »
Hello guys,
well it seems to keep temps under control, i will need to use an intercooler...
So.. do you think an air-air IC can cool enough in a notch or should i go water to air instead?
I was figuring to make a scoop in a spare decklid aronson style, but i dont know if ithe airflow would be enough to cool??
Ragtop
8.93 at SCC 2012
« Reply #1 on: February 22, 2011, 10:01:47 am »
It all depends on where you position it in the car. Is the car all steel or is it cut? I have mine in the middle of the car with fans sucking air through the IC.
« Reply #2 on: February 22, 2011, 10:39:49 am »
hello,
I would put it under the decklid,
and then a scoop on the lid...
but i dont know if the scoop will catch a lot of air?
Ragtop
8.93 at SCC 2012
« Reply #3 on: February 22, 2011, 21:12:12 pm »
I am not sure you will get enough cooling. Engine heat.
If you have a smaller IC from a SAAB you might be able to put it by the gearbox.
//Johan
Glauco
« Reply #4 on: February 23, 2011, 11:27:05 am »
BMW has some small intercoolers as wel, and they're pretty easy/cheap to find in belgium.
or something in the volkswagen range as well, just look at some diesel intercoolers because that kind of turbocars are found more in belgium than the petrol ones.
I'm going to try to put mine infront of the sump end go up from there, not sure if that will work, we'll see
mymedusa
« Reply #5 on: February 23, 2011, 12:27:01 pm »
but the bigger= the better  (core efficency beside)
4 factors: core size, volume of coolant( water or air), temperatur of coolant and efficency of the intercooler core.....also pressure drop should be a reason.
so what is your goal with it? want you go fast all the time or just for the stripe?
« Reply #6 on: February 23, 2011, 12:44:06 pm »
How does the air flow over a notch? Following the roof shape and creating turbulence behind the car or following the rear window down to the decklid? Why not use a huge and effective air/air intercooler that you integrate in the decklid completely? No scoop but just cut one big hole and paint it. You can also isolate it somehow from the engine heat and put a big bag of ice on top of it when you have to cool it down in between races  Smiley
<a href="http://www.youtube.com/v/qFpipRvzXo0" target="_blank">http://www.youtube.com/v/qFpipRvzXo0</a>
Glauco
« Reply #7 on: February 23, 2011, 13:19:17 pm »
http://home.comcast.net/~jaransont3/jaransonT3/AeroPage.html
I guess the big hole in the decklid could work and maybe ad some fans like ragtop does..
« Reply #8 on: February 23, 2011, 13:26:19 pm »
I wont drive fast on the highway : 90 - 100 km/h
the car is more for stop light action...
I want to go fast when i push the throttle Smiley
but most of the time i drive slowly with some fast bursts now and then ...
a water-air should be better i guess then?
« Reply #9 on: February 23, 2011, 13:28:47 pm »
Oh Kalle, i didnt see your post
It took too long to make mine Smiley
your idea sounds good, i dont like all the tubing water tank etc you would need for a water cooled..
« Reply #10 on: February 23, 2011, 13:31:47 pm »
That is what I call a GOOD link. Spot on as a matter of fact.
volkskris
« Reply #11 on: February 23, 2011, 13:40:50 pm »
this is how the intercooling is done on early 911 turbo's:
the grille from a 911 would be cool to hide the intercooler Wink
or the louvres from a beetle cabrio decklid
Kristof
« Last Edit: February 23, 2011, 13:44:51 pm by volkskris » Logged
« Reply #12 on: February 23, 2011, 13:45:52 pm »
And a bigger intercooler here:
<a href="http://www.youtube.com/v/0CwlJaeKQ_k" target="_blank">http://www.youtube.com/v/0CwlJaeKQ_k</a>
mymedusa
« Reply #13 on: February 23, 2011, 14:51:14 pm »
one big with fan or two ones with fan can do alot for you like armin klein do.
http://www.turboboxer.de/
for dragracing and short sprints the watercooled is very good and with a good made watertank you can add ice and get more than 100% efficency for te stripe. that can cool down to 10-20°C in the manifold.
we did such a setup during the days.
also in my engine bay you see nothing that say it is turbocharged.
wishes
from germany
chris
« Reply #14 on: February 23, 2011, 17:24:00 pm »
thanks guys,
well, there is a ghia lid for sale here,
i might take the louvres from that..
Glauco
« Reply #15 on: February 23, 2011, 17:37:17 pm »
wishes
from germany
chris
now that is exactly how I wanted it in the first place, thanks for this link, I'm going to contact this guy!
« Reply #16 on: February 24, 2011, 14:07:17 pm »
how about this one?
only 105 euro Smiley
Ragtop
8.93 at SCC 2012
« Reply #17 on: February 24, 2011, 15:15:37 pm »
Looks a lot like mine.
« Reply #18 on: February 24, 2011, 16:27:22 pm »
here is what I have air/water
The good thing about a air/water units is that they are more efficient and don't need to be as big
« Last Edit: February 24, 2011, 16:29:06 pm by Fiatdude » Logged
« Reply #19 on: February 24, 2011, 16:42:05 pm »
Hey Harold,
yeah, i know,
but i dont like the fact that you have to use water tank, hoszes etc..
But i still am not sure what to choose
Glauco
« Reply #20 on: February 24, 2011, 17:09:20 pm »
where are you going to mount the intercooler?
because maybe it's easier to take an intercooler where the inlet and outlet is on the botom or on the front, all to minimalise tubing work :-)
I'm going for a stock top mount impreza intercooler,becouse it has 3 exits, that makes it easier to go to the dubble throttle bodies
 not realy big, but it will mount under my 356 grill, think it will be cool enough there once I isolated it from the engine heat
and it was only 30euros, so that helps as wel :-D
« Reply #21 on: February 24, 2011, 18:03:01 pm »
I think just under the bonnet...
we ll see
