October 14, 2026, 19:31:44 pm
| | |-+  Mechanical Oil Pressure Gauges??
Author Topic: Mechanical Oil Pressure Gauges??  (Read 13468 times)
plasticblack
« on: February 22, 2011, 17:28:22 pm »
Does anyone on here have experiences with Meachnical type Oil Pressure Gauges?
  I'd be interested to hear any feedback and if possible know a little more about fittings and such?
     Any information would be of help thanks..  Smiley
plasticblack
« Reply #1 on: February 23, 2011, 00:19:34 am »
    Huh
     Does that mean nobody runs an Old Style mechanical gauge at all ..  Sad
« Reply #2 on: February 23, 2011, 01:05:19 am »
What exactly do you need to know ?
plasticblack
« Reply #3 on: February 23, 2011, 01:21:27 am »
Basically it would be great to know how accurate/reliable this type o gauge is?
 Is it really worth running 6/8 feet of tubing to have a correct period gauge or are these just Dinosaurs these days?
j-dub
« Reply #4 on: February 23, 2011, 02:49:41 am »
I am in the same spot. I am leary of running a oil line to the interior of the car.
I have heard they react instantly and may be more accurate than a electrical one. It was recently recommended to me to run a 2lb residual valve inline so the oil would not run  back to the engine, not sure where to source that.
jaqo
Bugster Team
« Reply #5 on: February 23, 2011, 02:51:51 am »
We have one of those autometer ones in Bugster and it sucks - it's very slow and has a lot of lag. But maybe there is something wrong with it, it's one of the last parts that we did not check after the car's ~10 years hibernation
« Last Edit: February 23, 2011, 02:53:42 am by jaqo » Logged
« Reply #6 on: February 23, 2011, 05:15:54 am »
It's all fun and games until the line breaks inside your car  Grin
Speed-Randy
« Reply #7 on: February 23, 2011, 05:24:35 am »
If by instantly you mean 1-2 minutes, then yeah, they're fast. Electricity moves at at approximatly 110,000' per minute,(if I remeber my apprenticeship lessons) fluid not quite as fast.
« Last Edit: February 23, 2011, 05:27:50 am by vdubdweeb » Logged
« Reply #8 on: February 23, 2011, 06:03:01 am »
Correct me if I'm wrong, but we're not talking about fluid, we're talking about pressure. And as long as there isn't any air in the lines, you should get a reading pretty quickly...
j-dub
« Reply #9 on: February 23, 2011, 08:27:13 am »
Man really? Do your brakes take 1 to 2 minutes to react after you push on the pedal?
« Reply #10 on: February 23, 2011, 08:40:43 am »
Always ran an Autometer mechanical gauge in my race car – very accurate, very quick to react. If it's slow to react it means the line needs bleeding... Run braided hose to the gauge, no problems.
plasticblack
« Reply #11 on: February 23, 2011, 11:24:27 am »
   Smiley  Good information. Thanks for the input.
          I'm going to give it a go.........   Cool
« Last Edit: February 23, 2011, 18:39:23 pm by plasticblack » Logged
Speed-Randy
« Reply #12 on: February 23, 2011, 16:43:26 pm »
Brakes are a closed system, engines are not. There are vents/breathers, when the engine is not running the oil drains from the galleys, brakes don't drain anywhere. Until all galleys are full you don't get pressure to push the oil to the gauge, and you can argue all you want, but it will never be as fast as electricity!!! And since that was one of the questions here, it has been answered.
Speed-Randy
« Reply #13 on: February 23, 2011, 17:00:04 pm »
Also, since electric fenders work in ohms(resistance), they are MUCH more accurate and reliable than a mechanical gauge. Use whatever you want, I don't care
« Reply #14 on: February 23, 2011, 17:10:30 pm »
i would like to connect my mechanical empi pressure gauges too
plasticblack
« Reply #15 on: February 23, 2011, 18:40:31 pm »
Hi Fabs
Do you have all the items you need to fit the Mech Gauges?  Cool
« Reply #16 on: February 23, 2011, 19:11:10 pm »
Hi Fabs
no
glenn
« Reply #17 on: February 23, 2011, 20:31:03 pm »
I've had a mechanical Stewart Warner oil pressure gauge since 1977. I ran 1/4" copper hard line up under the rear seat with a bulkhead connector. Then i run high pressure flexible hose that was made up at the local hydraulic shop for a few bucks. Never a problem.
You can see the copper line.
Here's the flex line under the car.
Here's the black covered flexible line to the port on the case.
Glenn
www.DasVolks.com
Long Island's Aircooled Club
jaqo
Bugster Team
« Reply #18 on: February 23, 2011, 21:44:56 pm »
I have a braided hose there. Actually the bleeding may help, will try that tomorrow.
plasticblack
« Reply #19 on: February 23, 2011, 22:51:19 pm »
Hi Fabs
[/quote]
no
[/quote]
What do you have & what do you need?  Smiley
Dougy Dee
« Reply #20 on: February 24, 2011, 14:57:38 pm »
I've run Autometer mechanical for 15 years. Horribly slow with small  oil lines but 5/16 diameter works fast even with 'heavy' 20/50 oil.
glenn
« Reply #21 on: February 24, 2011, 15:23:46 pm »
Mine has instant response.
Glenn
www.DasVolks.com
jaqo
Bugster Team
« Reply #22 on: February 24, 2011, 15:50:11 pm »
is there a procedure for bleeding it?
« Reply #23 on: February 24, 2011, 16:22:35 pm »
Get a bunch of rags and then just barely crack the fitting at the gauge until a couple of drops of oil come out
I ran a mechanical with the real small plastic line from the engine to the gauge -- was OK for a year or so until it "squirted out of the back of the gauge and then all over the inside -- good thing about the small line is when they do fail, it is not like someone turning on a garden hose -- went to 1/4" copper line the complete distance was solid mounted so never had a problem
I have a couple of brand new VDO mechanical temp gauges if anyone is interested -- 1 oil -1 water(gasp)
Deanodynosaurs
« Reply #24 on: June 01, 2011, 01:38:15 am »
Great thread!
I'm trying to work out wether i'm going to use a mechanical motometer guage in the ragtop i'm building, and the info in this has pretty much convinced me to do so. Smiley
Just a quick question though for those already running mechanical oil pressure guages. I'm gonna run the line through the car down the side of the tunnel, under the carpet. Is it ok to do this, or does the tube get really hot? Bit concerned about running it under the carpet if it does!!
Also which are the best lines to use? I think for the trial build of the car i will use a nylon line (much cheaper). However, for the actuall build, and once i know the correct length needed, i think i'll use a braided teflon line. Thoughts?
Dude  Cool
glenn
« Reply #25 on: June 01, 2011, 02:55:14 am »
Mine runs along the tunnel and it does not get hot.
Glenn
www.DasVolks.com
