September 22, 2026, 04:34:22 am
CB's Rotary Fuel pump
Topic: CB's Rotary Fuel pump (Read 17820 times)
Kaferdog
February 27, 2011, 19:16:10 pm »
Ok...Lookin for some opinions on this thought !..I'm thinking of running a CB rotary fuel pump instead of the Holly blue cuz I'm hearing too many stories about Hollys goin bad !....I've been hearing good things about the CB's....So now this is my question..! which one should I run the 3 1/2 or the 5 1/2...?..I will be running a regulator with a gauge because it's already there and I like the way it looks .......Any thoughts ?........
Re: CB's Rotary Fuel pump
February 27, 2011, 19:18:29 pm »
i have had the 3.5 for well over 14 years no problems.
Randy Jewell
February 27, 2011, 20:38:13 pm »
Quote from: Lids on February 27, 2011, 19:18:29 pm
But Lids have you taken it out the box and used it yet
Ive used the CB 3.5 for a few years with great results.
Andy
February 27, 2011, 20:52:07 pm »
Ditto. I have used the 3.5 CB rotary fuel pump for about 3 years now. I like it, its quiet and doesn't shake the hell out of the car...LOL!
February 27, 2011, 21:51:06 pm »
my holley went bad, got a facet red top now. the cb 3.5 looks good too, though i had to get a pump with threads to go with my plumbing
DVK ~
rick m
February 28, 2011, 00:01:16 am »
I have what I think is the CB 3.5 but it has been out of the wrapper for so long I cannot remember. What are the identifying numbers on the body of the fuel pump. I am just finishing up my fuel lines and getting the car ready to run and want to mount it once I'm sure I have the right one.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
February 28, 2011, 00:09:45 am »
I've been running my Holley Blue for going on 17 years now ... still no problems.
And, I made a custom bracket for it so it's rubber mounted and actually pretty quiet. You can just hear it power up before starting ...
Just wanted to throw a rock in the glass house!
But it is true.
Last Edit: February 28, 2011, 00:46:18 am by TexasTom
too old for this
February 28, 2011, 00:17:24 am »
Lids...you kill me........14 years ,no petrol,not turned a wheel,I would be surprised if it hasn,t fossilized
JG54
gizago
February 28, 2011, 00:58:42 am »
If you run the CB 3.5 you dont need the regulator, ditch it, less joins in the fuel line means less chance of leaks.
Dustin
February 28, 2011, 03:17:58 am »
I've been running the 3.5 for 3+ years. Quiet and trouble-free. No regulator feeding 48 IDA's!
Der Kleiner Panzers III
www.dkpcarclub.com
'69 Tangerine Orange Karmann Ghia- In progress
'66 Marina blue Chevy II Nova Hardtop- Project mothballed
Gabetion2000
February 28, 2011, 03:42:13 am »
I only had my cb 3.5 for 2 years, and it has failed. Holley here I come.
A and G's Racing
73 Super
February 28, 2011, 04:47:32 am »
I will be using the Mallory "Comp 70" 4070LP pump. 4 PSI , 70 gallons per hour, quiet, made in the USA, uses NPT fittings and rebuildable. I've been the Holley Red and Facet route and wanted something more reliable.
February 28, 2011, 06:20:24 am »
guys, thanks for all the positive comments
It was a street car until i moved house and decided to start fiddling with it. should have left it as a 1914 and driven it for the last 7 years!!! hopefully this year, just waiting on JC to build it.
Kaferdog
February 28, 2011, 07:14:29 am »
Guys.... Thanks for all the info...!...it's what I'm lookin for ..!..I thought I had the fuel line figured out but now I'm battling it out in my head..!it's the last thing before the motor goes in....! I want it to look good but want it to be reliable also..I was going via AN route with my fuel line .! which is already in place..!
Anyone have any pics on their fuel line system...?. ...I would like to get more Ideas
I would like to go with the CB but it doesn't have threaded fittings so I have to think of a second choice......
Last Edit: February 28, 2011, 07:39:49 am by Kaferdog
February 28, 2011, 07:20:06 am »
Randy, a Mallory. Can you hear mine when its on? OR, you can do the adapter thing for the push on lines at the tank, then AN from there. CB still sounds good though! And allot cheaper too!
Ted
Kaferdog
February 28, 2011, 07:42:44 am »
Quote from: racecraf on February 28, 2011, 07:20:06 am
Ted
Ted ...How much was your Mallory..?...If I can find a way to go from AN to the CB I'd run the CB 5 1/2 with my regulator
February 28, 2011, 08:05:47 am »
Can't remember but I did get it at McKenzies. Need to see a close up picture of the CB's to see what can be done.
Kaferdog
February 28, 2011, 09:00:45 am »
check it out ...
http://cbperformance.com/catalog.asp?ProductID=577
http://www.jegs.com/i/JEGS-Performance-Products/555/100581/10002/-1?parentProductId=1167165
christophe
March 02, 2011, 00:16:46 am »
Quote from: stealth67vw on February 28, 2011, 04:47:32 am
With regulator?That's a pump I considered as well.
March 02, 2011, 02:06:48 am »
Quote from: christophe on March 02, 2011, 00:16:46 am
Haven't got that far yet. I have the pump (after 6 months back order), but need to decide weather to go with a bypass style regulator or the standard Holley "red" regulator.
too old for this
March 02, 2011, 23:05:57 pm »
Quote from: Lids on February 28, 2011, 06:20:24 am
JG54
October 16, 2011, 23:06:12 pm »
Finally put fuel through my Mallory pump. I can barely hear it with the engine off. The pump on my wife's Chrysler mini van is louder. Solid 4psi with no regulator, but the instructions say I can slightly adjust the output pressure up or down by adjusting the bypass plug on the pump.
Kaferdog
October 17, 2011, 16:16:05 pm »
Yeah..... I ended up with the CB pump which is a Carter pump and I'm very happy with it !......I went with the 5 1/2 because I'm running a regulator .......I have it mounted on the firewall and can barely here it
GreenTom
October 17, 2011, 18:51:27 pm »
I use CB 3,5 PSI since 2006 no problem with it (especially with shity polish fuel). I put those in all my customers cars, never had problems with them also (the same with 5,5PSI).
by the way did any of you put a pressure swich with it?
Aircooled Performance Gear
Quick Stick Performance
www.QuickStickVW.com
Kaferdog
October 18, 2011, 20:43:16 pm »
No...just ran it with the regulator and thats it ...!
youngnstudly
October 24, 2011, 00:10:12 am »
What regulator are you running with that pump? I have a 3.5 PSI CB (Carter) pump and I was thinking about running a regulator with it to bring the pressure down to 2 psi. Thanks for the help.
Andy
Kaferdog
October 24, 2011, 08:35:00 am »
Quote from: youngnstudly on October 24, 2011, 00:10:12 am
What regulator are you running with that pump? I have a 3.5 PSI CB (Carter) pump and I was thinking about running a regulator with it to bring the pressure down to 2 psi. Thanks for the help.Andy I am running a holly regulator
Andy
Andy... I am running a Holly regulator...!
youngnstudly
October 24, 2011, 22:10:21 pm »
Thank you!
Andy
