October 14, 2026, 16:09:21 pm
| | |-+  midmount
Author Topic: midmount  (Read 4130 times)
« on: February 27, 2011, 20:21:44 pm »
hey,
do you still use the front rubber mount with a midmount? the back is also rubber.
« Reply #1 on: February 27, 2011, 20:28:26 pm »
I have VW grey rubber front, rubber midmount, solid rear.  I also have aluminium spacers to replace rubber blocks on midmount if necessary.  this was suggested to me by Max Morley.
gizago
« Reply #2 on: February 28, 2011, 00:57:26 am »
Surely that would create a stress point around the rear mounts, if the rest is rubber mounted it will try to move around the solid mounts?? I would have thought you would want all rubber or all soild?
« Reply #3 on: February 28, 2011, 06:18:20 am »
to be honest i have no idea, but if max said it.....its probably okay.
I do know once you mid-mount the front mount is not needed, so the rubber here must be to stop vibrations and noise.
Joel Mohr
« Reply #4 on: February 28, 2011, 17:52:44 pm »
ALL rubber or ALL solid! That's why I developed the "Traction Control" as I first called it. Now everyone just calls it a mid-mount....The one with the pads that contact the frame horns.
« Last Edit: February 28, 2011, 17:55:04 pm by Joel Mohr » Logged
SEE YA AT THE RACES!!!
