October 13, 2026, 08:09:51 am
Bugpack flanged crank..any good for high horsepower?
Topic: Bugpack flanged crank..any good for high horsepower? (Read 21830 times)
JIMP
March 03, 2011, 10:23:51 am »
Hello all
we're setting our race car on a new case and crank (probably wbx case or aftermarket alu) and was thinking about the crank, will a bugpack flanged crank be good for our race engine? it will be in the region of 78-82mm on chevy journals, power in the region of 500Hp for drag racing, can you rely on this crank for this application? we do max 20-25 passes per season, and then we check it again
Also this 6pin and 6bolt design of the bugpack is smaller in diameter than the newer 8bolt of scat's? as it will be easier if we go with the wbx case, thanks for your time
Friendly
Dimitrios
still-water
Re: Bugpack flanged crank..any good for high horsepower?
March 03, 2011, 12:30:04 pm »
Hi,
I think the Bugpack cranks are very good quality for the money (always been pleased with my Bugpack cranks using them since the 90') and at least there is some control on their cranks they're selling.
One question for you Dimitri; I noticed you're trying to sell 2 SCAT flanged -cranks since a while...did you got bad experience in one or the other way you want to share with us ? Maybe there's a reason you are changing to another brand of crank?
Good luck with your project
JIMP
March 03, 2011, 13:46:43 pm »
Hello
no please it's a missunderstanding, I sell those cranks because don't have what to do with them, I have already one in my street engine, I just need for the race engine a smaller one 78-82mm because I want the case to be as intact as possible without removing material from it, also I'm afraid of the "little coverage" between the main and rod journals, especialy on a big 86mm with a chevvy rod. Also I have the impression that bugpacks are at least "fair" for their price as you mentioned, and this is why I'm asking, if anyone has personal experiences of those ones, cheers
Friendly
Dimitrios
Dominick Luppino
March 03, 2011, 16:08:23 pm »
I use the BUGPACK Flange Crank in my car, Turbo & Nitrous making over 500hp, I know The Red Baron used one also.
ugly duckling
March 03, 2011, 17:35:36 pm »
I wouldent hesitate is the least to using one. For the money its an excellent part. .UD.
www.dprmachine.com
www.4inbore.com
jeffsvwspeed@gmail.com
dragvw2180
March 04, 2011, 01:31:04 am »
I have used two Bugpack flanged cranks and both worked well with no problems, would use them again. Another good crank is made by REVMASTER, that is what I am using now with BMW center main, Mike
JIMP
March 04, 2011, 09:22:27 am »
Well
thanks a lot for your inputs, it's exactly what I thought of initialy about those cranks, do we have posibility for all T4 mains on those or they come with T4 center main only? I'm trying to access the bugpack site and won't go through, cheers
Friendly
Dimitrios
Rick Sadler
March 04, 2011, 17:36:02 pm »
The BUGPACK Site has been hacked numerous times and is in the rebuild process. All current (past 10 years) flanged cranks have all type-IV main journals and chevy rod journals.
Last Edit: March 04, 2011, 17:37:39 pm by Rick Sadler
dangerous
March 05, 2011, 22:42:45 pm »
Thanks for the information Rick.
Does Bugpack have main bearings for these cranks,(all type 4 mains),
and flywheels.
...and do they have a distributer with online ordering?
Thanks.
Rick Sadler
March 06, 2011, 18:38:47 pm »
The only bearings we carry are the conversion (BMW) bearings that allow the use of a standard type-I align bore case. T use these bearing on the number 1, 2 , and 3 mains you will need to to do the center thrust set-up like Jack at Jay Cee Ent does 714-444-4344 (
www.jaycee-ent.com
). As for dealers on line Vee Dub Parts Unlimited 714-848-8868 (
www.vwparts.net
) can assist you or you can call BUGPACK at 714-979-4990 for a dealer near you.
JIMP
March 06, 2011, 18:49:14 pm »
Hello Rick
thanks for the info, we will be using a wbx case the later one with the tangs on the bearings instead of dowel pins and the seperate thrust bearing at the flange side, we need also the center main modiification or we can retain the existing thrust surface of the flange bearing? In this case at what size has the case to be linobored -T4 std or other? thanks in advance
Friendly
Dimitrios
March 06, 2011, 19:13:53 pm »
Remember that the wbx case has a 1 mm smaller thrust bearing . so you must weld the case or use the center thrust conversion.
My crank 84mm works fine so far :-)
www.Udobeckertuning.de
daniel1366
January 12, 2012, 19:06:10 pm »
Hi to all. Quick question, dose Bugpack still makes 78mm flange cranks? Thank you.
January 12, 2012, 20:54:23 pm »
Quote from: Rick Sadler on March 06, 2011, 18:38:47 pm
www.jaycee-ent.com
www.vwparts.net
I think i found a good solution . Modified original bmw bearing. I try it out this year on my engine first
Rick Sadler
January 13, 2012, 00:28:14 am »
Quote from: daniel1366 on January 12, 2012, 19:06:10 pm
I don't think we ever had 78mm in a flanged version. As for now, we do not.
daniel1366
January 13, 2012, 01:59:31 am »
thanks Rick.
January 13, 2012, 21:30:33 pm »
hello Udo,
did you have to cut the case for the thrust plates?
Did you make these yourself?
great work! and cool that somebody in europe can do it
cheers, Peter
Shag55
Shag Leone, SL-1racing
January 13, 2012, 21:41:46 pm »
I'm making jigs to use a bearing bronze thrust washers in the rear as factory. The bearings will be the correct OD and ID for the flange crank With plenty of chamfer and oil dimples. They will fit in either type 1 or 4 journals and for the 4" seal. Only as my jig will be made for this. I'm getting close, but sorry not in Europe. Machining will be done through Brothers VW.
Shag55.sl1racing@gmail.com
Facebook at SL 1 racing
daniel1366
January 15, 2012, 02:58:47 am »
Is this an old ad? a 78mm flange crank is listed.
Home :: About Us :: What's New :: Tech-questions :: Dealer Links
Categories
ENGINE (227)
INTAKE (57)
EXHAUST (28)
TRANSAXLE (54)
INTERIOR (78)
EXTERIOR (64)
CHASSIS (15)
SUSPENSION (61)
TOOLS/BOOKS (60)
WATERCOOLED (1)
Home :: ENGINE :: FLANGED CRANK & FLYWHEEL
larger image
Totally forged (Both Crank & Flywheel) and totally bulletproof! Flanged configuration delivers maximum contact area…while the 6 bolt, 6 pin design eliminates flywheel loss. Available in all popular combinations and options offering you everything you need for your ultimate high horsepower engine. In stock for immediate delivery!
4000-25 Forged Flanged Crank 78mm, Chevy Journal
4000-31 Forged Flanged Crank 82MM, Chevy Journal
4000-26 Forged Flanged Crank 84MM, Chevy Journal
4000-27 Forged Flanged Crank 86MM, Chevy Journal
4000-28 Forged Flanged Crank 88MM, Chevy Journal
4099-20 Forged Flanged Flywheel 12V 200MM Clutch
4099-21 Forged Flanged Flywheel, J&G clutch
4099-22 Forged Flanged Flywheel 12V Tilton Style Clutch
4099-24 Flanged Flywheel (ARP) Bolts, 6
4000-70 Special Main Bearing Set, Flanged Crank
4000-71 Flanged Crank Flywheel Seal
4000-72 Input Shaft Bearing for Flanged Crank
4000-60 Spl. Cntr. Main Brng, 411 Inner w/T-1 Outer Dia.
•CRANK FEATURES•
•Forged from 4340 Chromoly Steel
•Type IV Center Main for Rigidity
•2” Rod Journal (Chevy)
•Split Main Bearing Sets Available
•Nitrided Bearing Surfaces
•FLYWHEEL FEATURES•
•Forged (not machined from billet)
•Original Factory Surface Hardness
•Two Models -Standard & Tilton
•Special ARP Flywheel Bolts Available
•Heavy Duty 12V Starter Ring Gear
Tell a Friend
Write Review
Product 105/227
Previous
Return to the Product List
Next
Home
BUGPACK Products, 3560 Cadillac Ave.,Costa Mesa, CA 92626,
Ph: 714-979-4990 Fx: 714-979-3468 ©All rights reserved, BUGPACK.com 2009.
Powered by Zen Cart. Developed by Dotcommakers.com
daniel1366
January 15, 2012, 03:01:24 am »
http://bugpack.com/index.php?main_page=product_info&cPath=2&products_id=5
this is better.
January 15, 2012, 09:02:01 am »
Quote from: Peter on January 13, 2012, 21:30:33 pm
hello Udo,
cheers, Peter
No machining for the bearings. only for the seal .
Yes , i do it at my shop.
Rick Sadler
January 16, 2012, 00:58:34 am »
Quote from: daniel1366 on January 15, 2012, 03:01:24 am
this is better.
this is better.
Quote from: Rick Sadler on January 13, 2012, 00:28:14 am
We were hoping to add these to the line last year but we did not. I will make sure our website is updated. Sorry for any confusion.
January 16, 2012, 01:04:12 am »
Quote from: Udo on January 15, 2012, 09:02:01 am
hello Udo,
cheers, Peter
Looks intriguing Udo!
Care to educate? What process is used to cut the thrust bearing?
TxT
January 16, 2012, 13:02:43 pm »
I eroded it , i think it is the only way to do it
