September 09, 2026, 06:00:23 am
Latest Member: Bad Habit
| | |-+  Magneto and sparkplugs
Author Topic: Magneto and sparkplugs  (Read 14446 times)
Berger
www.bugrent.no
« on: May 08, 2006, 10:36:28 am »
I run a 2276 with SF heads, 11,5:1 komp and a Joe Hunt magneto. This works fine except for the plugs beeing worn out after a few runs. The plug itself looks fine, but the spark is just not god enough to get the engine started. New plugs and it fires up just fine. I have tried several brands of sparkplugs with the same result.
Last I used Bosch W7AC with std gap.
Anyone with some magneto excperience who can help?
« Last Edit: May 08, 2006, 12:20:30 pm by Berger » Logged
This is my simple religion:
-Be cool
-Don't be an asshole
Ole
« Reply #1 on: May 08, 2006, 21:20:32 pm »
Last season I used BERU 14-7AU, that's equal to your BOSCH W7 AC. They work fine (Joe Hunt mag; CR 12.0; Mallory Pro Wire). I had problems getting the engine started with the stock starter. A late 6V starter run with 12V solved the problem.
Saludos,
Ole
no cerveza?
no trabajo!
Berger
www.bugrent.no
« Reply #2 on: May 09, 2006, 08:03:07 am »
Thanx Ole. I use Taylor wires.
So You say low "starter-rpm" was the problem? Means that the magneto produce weak spark at very low rpm?
How do You gap Your sparkplugs?
-Be cool
Ole
« Reply #3 on: May 09, 2006, 11:52:36 am »
Yep, at least it solved my case. I almost went mad when the engine didn't fire up. After 1/2 hour rechecking everything without any result, I put 24V on the starter for the last try... it started up immediately. I was happy, my neighbors not... Grin
I use the std spark gap (approx. 0.7mm)
Saludos Ole
no cerveza?
no trabajo!
« Reply #4 on: May 09, 2006, 14:02:02 pm »
Part of your starting problem is that the plug gaps are too wide for a magneto. You should regap the plugs to 0.5mm.  Cool
Ole
« Reply #5 on: May 09, 2006, 16:14:26 pm »
Thanks for the advice! I'll try that next time. I need to figure out some other spark plugs anyway. Due to some head welding, it was necessary to modify them to accept 12mm plugs. Guess I'll try NGK DPR5EA-9 or NGK DPR6EA-9. Any suggestions?
no cerveza?
no trabajo!
Berger
www.bugrent.no
« Reply #6 on: May 10, 2006, 10:10:26 am »
Thanks for the replys  Smiley
Re-gapping of sparkplugs and installing a new starter wil be done!l
-Be cool
« Reply #7 on: September 01, 2006, 15:14:50 pm »
Hey, guys.
Im putting together my 2176 these days, and the Vertex gets a few needed goodies to. A new cap, rotor and a 12° ignition curve. I also want to customize my Pro controller to two step... as I have a serious problem with growing horns on the start line.  Grin
But what kind of ignition wires should I get, I don't want anythig to fancy as I want a "old" look to my engine. Does summit have anything for me?
