September 29, 2026, 23:22:26 pm
| | |-+  Jetting a Holley 750 for turbo
Author Topic: Jetting a Holley 750 for turbo  (Read 7218 times)
flatfire
« on: March 10, 2011, 10:45:34 am »
Hi Guys, has anyone used a holley 750 for a turbo application?
I have a 750 holley and I am almost finished my turbo engine. I want a starting point as far as primaries and secondaries are concerned.
Engine 84 crank 94mm pistons AJ Sims LB 5 cam and AJ sims prepped comp eliminators good for in excess of 400 hp.
I want to dial in the car with perhaps 12 psi of boost. The primary in the carb is 70 the secondary 76. The turbo kit is a Ron Lummus. Smiley
cheers
« Last Edit: March 12, 2011, 12:09:58 pm by flatfire » Logged
Martin Greaves
10.88@128.58
« Reply #1 on: March 10, 2011, 19:53:29 pm »
Peter is the power valve blocked off.
« Reply #2 on: March 10, 2011, 21:12:02 pm »
I think if you have the carburator from ron the jets would be ok for testing
flatfire
« Reply #3 on: March 10, 2011, 21:55:16 pm »
No Martin the Power valve is open.
Your right Udo the carb should be okay. Ron jets them to suit a particular engine. Being a tight Scot, I bought the turbo kit secondhand even though the kit looked brand new.
Thanks for all the replies Smiley
Martin Greaves
10.88@128.58
« Reply #4 on: March 10, 2011, 22:18:10 pm »
You got a PM.
dragvw2180
« Reply #5 on: March 18, 2011, 17:14:34 pm »
 Since your power valve is boost referanced you may want to go to the Holley website and retrieve the formula for determining the size power valve you need.  All the jetting in the world will be tough until you get the right power valve in it. Every combo is differant but for referance mine is 4.5  .   Mike
Dominick Luppino
« Reply #6 on: March 18, 2011, 20:50:04 pm »
If Ron set the carb up originally it should be close.
flatfire
« Reply #7 on: March 22, 2011, 20:42:00 pm »
Thanks guys. I will post my up the information I gather once the engine is up and running. Smiley
jamiep_jamiep
« Reply #8 on: March 23, 2011, 09:07:05 am »
Thats interesting Mike, I'm just referencing my Holley 650 DP now (its plugged at the moment) and have beena dvised to run the lightest possible.... I have a 4.5 already however so may give that a try....
