October 14, 2026, 10:12:31 am
| |-+  For sale!
| | |-+  Race Engine 2275 JayCee
Author Topic: Race Engine 2275 JayCee  (Read 2446 times)
Herbie51
« on: March 10, 2011, 16:58:00 pm »
Engine is 82x94, blueprinted and balanced by JayCee. Case is CB mag case with the following modifications: Pluged for JayCee bypass oil system, lifer bores sleeved, cut for sandseal and flanged crank. Jaycee center flanged bearing. Crank is Bugpack 82mm flanged with chevy rods bearing clevite CB610P and T-4 center main. Bugpack flanged flywheel with ARP bolts. 10mm cylinderheadbolts ARP. 5,5" CB super race rods, Engle FK89 cam, CB 2pc racing lifters, pushrods and tubes from JayCee, Pistons are Venolia and barrels by JayCee Dykes rings. Compression is 12,54:1
CB comp Eliminator heads 46x38 fullport and polish stainless valves K800 springs, titanium retainers, CB 1,4 rockers CB valvecovers.
JayCee 51,5 carbs with all the tricks. CB intake and linkage
30mm HD oilpump CB billet alu oil pump cover, CB straight cut camgears, JayCee oil bypass filter, Geers cranktrigger.
Kennedy stage 1 pressureplate with blackmagic disc, Bugpack ceramic coated 2" exhaust with tig welded plugs for EGT.
Complete MSD igniton with 6 Digitalbox and blaster coil.
Holley fuelpump and regulator.
This engine has went 25 passes last season and are now inspected and together again. The engine are in my car now and can be tested.
Race Ready!
Price: 53 000 SEK
Contact: +4670-361 33 36
Mail: anteaberg@hotmail.com
