September 22, 2026, 03:39:56 am
Diederick's '67
13
14
Topic: Diederick's '67 (Read 254945 times)
Eddie DVK
Re: Diederick's '67
Reply #390 on:
February 02, 2012, 23:16:49 pm »
http://www.luchtgekoeldewebwinkel.nl/webwinkel_product.php?product_id=2436
Regards Edgar
Regards Edgar
Re: Diederick's '67
Reply #391 on:
February 03, 2012, 13:46:21 pm »
eddie, the thing is my crank gear is just fine. so i was hoping someone could help me out with just the cam gear
DVK ~
Eddie DVK
Re: Diederick's '67
Reply #392 on:
February 05, 2012, 10:40:53 am »
Quote from: 67-indeed/DVK on February 03, 2012, 13:46:21 pm
Oeps sorry.
Regards Edgar
Re: Diederick's '67
Reply #393 on:
February 05, 2012, 19:38:49 pm »
Dude I would replace BOTH just to be on the safe side - You know it makes sence
Re: Diederick's '67
Reply #394 on:
February 05, 2012, 20:34:56 pm »
i was not aware they are matched sets? a magnum cam gear should work with a magnum crank gear, right?
DVK ~
Re: Diederick's '67
Reply #395 on:
February 05, 2012, 20:59:03 pm »
I just ment are you
100%
sure that the other gear is not damaged - just seems silly not replacing it while the motor is apart
Re: Diederick's '67
Reply #396 on:
April 25, 2012, 15:05:03 pm »
hey Diederick,
hows the motor?
are you running a locked mag?
Re: Diederick's '67
Reply #397 on:
April 26, 2012, 14:31:09 pm »
the motor is back together. i should get round to installing the gearbox tomorrow when more parts arrive. after that i can install the engine and replace the front beam and do some finetuning once i get the car up and running. i am running a locked magneto, yes.
DVK ~
13
14
