October 12, 2026, 18:30:57 pm
| | |-+  Diederick's '67
Pages: 1 ... 5 6 [7] 8 9 ... 14 Print
Author Topic: Diederick's '67  (Read 258954 times)
« Reply #180 on: October 03, 2007, 03:24:57 am »
so my question is, when the hell is the big motor going in? These 94's are getting sick of sitting on my workbench! Grin
yvre
Der Autobahn Scrapers
« Reply #181 on: October 03, 2007, 09:58:50 am »
I see you still haven't put the trim back... Regretting not dechroming the car?
You could always paint the trim green to match the car - I haven't seen this trick in a long time.
« Reply #182 on: October 03, 2007, 10:25:09 am »
the big motor is going in as soon as it's been built  Roll Eyes
 Grin definitely before next season
and yvre, yes i regret it big time.  Undecided
still i'm going to put the trim on, but i need to get new trim pieces for under the quarter windows as my own aren't straight.
« Reply #183 on: October 22, 2007, 11:56:41 am »
mmh, match painting the trim... what does everyone reckon  Wink
i felt like tinkering yesterday so i swapped the rear shocks with my brother to get the back up a tad, to get a nicer rake and to get clearance the muffler.
now i run coil over shocks in the rear and the back end has been raised by like 5cm.
i will adjust the coil over shocks to the lowest setting (does anyone know how much this changes the height)
but i've also heard that installing a larger engine also lowers the back end because of the added weight.
is this true, and/or does this only count for stroker engines?  Wink
« Reply #184 on: October 22, 2007, 13:44:48 pm »
The Trim would look good Painted Body Color they do it on Porsches and Corvettes so why not Bugs as Far as the rear height it is to High for my Taste your car Looked better before you raised the rear if you could split the difference between how it was before and how it is now it would look ok  I like the top of the fender edge to be right at the top of the tire. so you see the full tire but no gap between just my 2 cents  How is the New Motor coming?? or Do Like Hans Motor Better LOL Grin Grin
« Last Edit: October 22, 2007, 14:00:53 pm by Shubee2 (DSK) » Logged
« Reply #185 on: October 22, 2007, 14:00:05 pm »
hehe, my b-day is this friday so i'm gonna treat myself by sending out my case for machining  Wink
but i've got all the specs figured out. and i've got the next updates for my 67 in mind. however, money is the issue  Undecided Wink
thing is i'm gonna try the match painted trim, i only have 1 bonnet trim ('67 only) so i gotta be sure or do it in 2 steps.
also, i agree with the rear height gary! but i will see how it turns out when i adjust the coil overs.
does anyone how to do this?  Roll Eyes
« Reply #186 on: October 22, 2007, 14:10:22 pm »
depends on the coil overs you have the ones I have seen the bottom spring collar rides on two stops you have to compress the spring and rotate the lower spring collar to the lowest setting most shocks have three settings I have always found that the coilover shocks are stiff they were used more for a Baja then a Street Car 67's have soft torison bars thats why the sit low you could always adjust the preload on the rear bars
« Last Edit: October 22, 2007, 14:14:20 pm by Shubee2 (DSK) » Logged
« Reply #187 on: October 22, 2007, 14:18:32 pm »
those are the ones i have, but how do i compress them?
i know i should adjust the torsion bars, but then i'd have to call in favour again. cos i still haven't fully figured that out myself.
they are stiff indeed, but it's not that uncomfy i reckon.
but i'm aiming for a rake like harvey rosenthal's 66, which i think is purfect  Cool
« Reply #188 on: October 22, 2007, 14:34:50 pm »
the way I use to do them  is take them off the car so there fully open but the bottm eye of the shock in a vise and use a pir of channel locks to rotate the collar what setting are they on now?  if it were me I would put a pair of the White KYB gas A Just Shocks on the rear they will raise the car almost 1 inch and they ride good never use them in the front there to stiff.
« Reply #189 on: October 22, 2007, 14:43:46 pm »
i used grey KYBs before this.
they are now on the lowest setting which means the highest overall length. so i should be able to lower the rear 2 more clicks.
« Reply #190 on: October 22, 2007, 15:04:02 pm »
[/quoteadjust them all the way the other way and try that The White KYB's are stronger and stiffer then the grey KYB's
« Reply #191 on: October 22, 2007, 22:01:11 pm »
those coil over shocks are typically made with a poor quality shock that gets "overworked" from the coil and torsion spring, and will die an early death. Then you've got a messy handling car on your hands. Trust me, I tried those years ago. In a matter of a few months they were dead and my car was a nightmare to drive. KYB gas are good, affordable shocks.
« Reply #192 on: October 22, 2007, 22:42:32 pm »
and the whites will raise my rear too? cos otherwise it makes no sense buying them...
are those adjustable?
« Reply #193 on: October 23, 2007, 00:23:27 am »
they are stiffer then the grey KYB's they all called KYB Gas Adjust,  I have always found that the coilover shocks are stiff they were used more for a Baja then a Street Car 67's have soft torison bars thats why the sit low you could always adjust the preload on the rear bars
« Last Edit: October 23, 2007, 04:29:31 am by Shubee2 (DSK) » Logged
« Reply #194 on: October 23, 2007, 02:38:51 am »
Theres only one way to raise your car and its not changing the shocks. You need to readjust the torsion bars.
« Reply #195 on: October 23, 2007, 03:11:34 am »
Bryan's right. And by the way, KYB = Kick Your Butt. I hate those shocks!
« Reply #196 on: October 23, 2007, 17:45:29 pm »
a shock absorber should never be used as a way to raise ride height.
« Reply #197 on: November 25, 2007, 18:24:51 pm »
all right folks, i fitted my white KYBs today - at the expensive of a very painful thumb that almost lost its nail, but don't ask how i managed. haha.
this is the result, the wheels stand nice and straight with no more negative camber.
also i fitted some extra gaskets and i'm through with the tractor sound it had  Cheesy
click on the links for the larger pics, i didn't want to ruin the layout  Wink
http://www.cal-look.nl/gallery/albums/userpics/10005/25112007052.jpg
http://www.cal-look.nl/gallery/albums/userpics/10005/25112007053.jpg
http://www.cal-look.nl/gallery/albums/userpics/10005/25112007054.jpg
what say you?
« Reply #198 on: November 25, 2007, 19:00:32 pm »
lookin good dude  Smiley
« Reply #199 on: November 25, 2007, 19:05:07 pm »
nice one diederick
 Wink
« Reply #200 on: November 25, 2007, 19:41:53 pm »
cheers guys  Wink
other updates are going to be new license plates (in a nice frame).
and i figured that mounting my chrome moldings/trim with trimless window rubbers could make another nice solution.
somewhat like these pics i found in an old topic:
watch how cool that "single line" is in the second pic
Grelland
« Reply #201 on: November 25, 2007, 19:51:31 pm »
whoaa what happened to that silver split???
___________________
Roy
Jordy/DVK
« Reply #202 on: November 25, 2007, 19:55:00 pm »
 Damn... three very very very old splits in a single line!  Shocked
 Yummie.... If it ain't split it ain't sh*t...  Grin
  "The Full-Throttle Cruisers"
« Reply #203 on: November 25, 2007, 19:56:49 pm »
Those cars are here in Oregon, owned by Brian Hyerstay. He owns a NHRA G/Dragster and this 46 standard and posts here under 1946vw.
« Reply #204 on: November 25, 2007, 20:09:28 pm »
hola, don't hijack my thread!!
i was merely trying to point something out  Wink Grin
« Reply #205 on: November 26, 2007, 00:14:01 am »
cool car my friend Smiley
i thought the black trim would be cool also
cheers, Peter
« Reply #206 on: January 05, 2008, 20:33:02 pm »
bought 2 sets of chrome trim today. one is stainless steel and one aluminium set that i might use for match painting.
oh and i found some nice pics of last summer on my brother's pc:
« Reply #207 on: February 10, 2008, 19:03:02 pm »
for my dashboard i'm looking for some dash/gauge panels.
what i need is one 10cm hole on the left panel, and two 2 1/16" holes on the right panel.
now, the one in the right is no problem. but for the left hand side all i can find are these:
and 2427
i'd prefer them "filled" so no grill. and i'm still undecided as to the finish, smooth or wrinkle paint.
any ideas?
« Reply #208 on: February 10, 2008, 21:10:54 pm »
wrinkle paint is cool. it looks like a mach1 car. but those were red... but it works as well with green.
« Reply #209 on: February 10, 2008, 21:16:08 pm »
yeah! i'm still pretty divided on it. it's all guessing to me Wink
any idea where i can get the gauge panels?
