November 03, 2026, 00:54:25 am
| |-+  For sale!
| | |-+  Doghouse cooler, IDF linkage brackets etc.
Author Topic: Doghouse cooler, IDF linkage brackets etc.  (Read 11771 times)
-Alex-
« on: March 13, 2011, 16:14:41 pm »
New doghouse cooler with original cleaned and glass bead blasted bracket
50 euros
shipping 25-35 euros inside europe
Lasercut linkage brackets for IDF/DRLA carbs, fits with straight manifolds
30 euros
shipping 20-35 euros inside europe
Lasercut 3mm high strenght brackets for recaro seats. Height 155mm, 2 degree tilt, 450mm width at the top, 400mm at the bottom, lenght 400mm, 406x337 boltspacing for M8 bolts. Includes endplates which gives more strenght.
70 euros CHEAP
shipping 40-60 euros inside europe
-Alex
Parts are in Finland. .
Email or PM if interested.  alexstorskrubb@jippii.fi
« Last Edit: May 05, 2011, 11:03:16 am by -Alex- » Logged
-Alex-
« Reply #1 on: March 22, 2011, 20:45:28 pm »
up
-Alex-
« Reply #2 on: April 17, 2011, 16:17:19 pm »
up
-Alex-
« Reply #3 on: April 26, 2011, 06:56:34 am »
up
-Alex-
« Reply #4 on: May 03, 2011, 13:06:33 pm »
up
bugnut68
« Reply #5 on: May 05, 2011, 19:17:13 pm »
I love the look of those IDF/DRLA brackets... what kind of crossbar do they accept?  I have some linkage parts but am missing the brackets you have there.  My cross bar has the ball end threaded into the crossbar itself, which is different than the CB Performance type hex bar that has the ball end that bolts to the bracket.
What kind of set up do your brackets employ?  Do the ball ends bolt to the bracket?
Paul da Graca
« Reply #6 on: May 10, 2011, 22:08:52 pm »
Alex send you a PM
-Alex-
« Reply #7 on: May 11, 2011, 06:45:45 am »
Brackets accept normal crossbar, just need to make specific threaded ends with nuts. I have used this type of brackets before. With two nuts you clamp the threaded end to bracket and with third nut, you adjust crossbar endplay.
« Last Edit: May 11, 2011, 06:54:05 am by -Alex- » Logged
