October 12, 2026, 12:00:04 pm
| | |-+  The GTV
Pages: 1 ... 7 8 [9] 10 11 12 Print
Author Topic: The GTV  (Read 524278 times)
« Reply #240 on: May 19, 2011, 17:50:01 pm »
Thanks Smiley Once I sort this pulley tin/draft tube issue, all I'll have left is the type 4 cooler mod and the venturi ring on the back of the shroud... fingers crossed.
cal-look 56
« Reply #241 on: May 19, 2011, 18:16:02 pm »
Progress is a slow process.  Take your time, it will be worth it
« Reply #242 on: May 19, 2011, 20:49:49 pm »
Try explaining that to my missus!  Grin
« Reply #243 on: June 24, 2011, 16:37:31 pm »
Ok, so I'm finally ready for powdercoat Smiley
Got the Berg T4 tin conversion on and to my liking. Welds ground down for a factory appearance Wink I ended up redesigning the area at the bottom where the air enters the cooler, made it much simpler and a little like a late model fuel injection shroud- I eliminated that U shaped piece and just made a straight shot to the cooler. This mod really is a lot of work if you want to do it correctly! I also had to modify my original exhaust ducting to fit (I didn't have the Berg piece). Venturi ring blasted and on. While I was there I decided to clean up the face a little, I removed the wire tabs and filled the breather tube at the top right, etc.
I also put a breather fitting on my 1-2 valve cover. I couldn't figure how I wanted to approach this until I had a flash of genius the other day Smiley I removed the factory breather tube on one of the late model fuel injection shrouds that I had already cut up, trimmed it to fit, drilled a hole in the cover and welded it on. Factory modified parts! And it was free! Little things like that make me very happy!
Anyway, got everything fitted up for the last time, (with EMPI header Cool) and snapped a pic before I tore it all back apart. The front tin is slightly askew, the engine stand doesn't let it sit all the way down...
While the tins are off at powdercoat I will figure out my pushrod length, install my distributor, fuel pump, and finish the carb rebuild...
Im still looking for an oil cap that fits the stock VW filler but allows the engine to breathe. I see ones for V8 cars everywhere... any ideas Huh
« Reply #244 on: June 24, 2011, 17:56:05 pm »
Zach what is the purpose of the TIV tinware conversion?
« Reply #245 on: June 24, 2011, 18:21:41 pm »
Bigger oil cooler Wink
« Reply #246 on: August 13, 2011, 15:13:24 pm »
OgCalLook
Straight outa Riverside!
« Reply #247 on: August 13, 2011, 15:55:33 pm »
 Cool Steady progress..... good job, keep after it!!
Tom Hewitson
Bahama Blau Kafer
Zach Gomulka: "California Look is walking softly and carrying a big fucking stick."
« Reply #248 on: August 13, 2011, 16:01:05 pm »
I have to keep after it... gotta move in 2 weeks Shocked
Sam K
« Reply #249 on: August 14, 2011, 03:43:13 am »
Looks great! The coil relocation brackets look like the ones on Dave Rhodes' car. Did you make them?
« Reply #250 on: August 14, 2011, 17:12:17 pm »
They came with the NOS EMPI linkage that's gong on the motor.
Sam K
« Reply #251 on: August 14, 2011, 17:39:45 pm »
Awesome.
« Reply #252 on: August 14, 2011, 19:41:18 pm »
 Wink
« Reply #253 on: August 14, 2011, 20:10:53 pm »
I wish I had some air cleaners! But I'll just run wide open until I happen across a set for a reasonable price...
I still haven't figured out what I'm going to do about a breather :/
« Reply #254 on: August 14, 2011, 20:16:08 pm »
I love the blue fanshroud on the Empi engine.
« Reply #255 on: August 14, 2011, 20:38:40 pm »
is it the same blue that the one on the bosch 019 in the screamer kit Huh
« Reply #256 on: August 14, 2011, 21:14:03 pm »
Don't know but indeed it would be even better with a Screamer 019!
« Reply #257 on: August 14, 2011, 21:47:09 pm »
very cool engine! it looks like metallic blue, pretty nice!
just not too sure if white is the proper colour for the header and heaterboxes Wink
fredy66
« Reply #258 on: August 14, 2011, 23:13:21 pm »
and the air filters love them
arabia slugs
« Reply #259 on: August 14, 2011, 23:27:47 pm »
I don't think the blue on the shroud is the same as an 019. The 019 uses a hammertone type blue, similar to the old Berg blue.
My heater boxes are going back to grey, just like factory. I'm not sure why that header is painted white, they came "flash chromed" from EMPI.
« Reply #260 on: August 15, 2011, 09:22:39 am »
because its cool
« Reply #261 on: August 15, 2011, 15:20:01 pm »
I have a very early version of that exhaust / header that came painted the Empi light blue.
P.S. Why stock valve covers ?
« Reply #262 on: August 15, 2011, 18:37:44 pm »
I found and restored a pair of original non GT covers, but I'm lacking the correct hardware...
fredy66
« Reply #263 on: August 15, 2011, 23:08:47 pm »
dos the t4 cooler work?  is it o good thing to do ??
arabia slugs
« Reply #264 on: August 15, 2011, 23:16:59 pm »
Yes. I live in Arizona, so it's almost mandatory here Wink I also increase the fan speed at the same time with a 356/912 gen pulley.
fredy66
« Reply #265 on: August 15, 2011, 23:49:13 pm »
bigger pulley at the generator side. that my  not be the best solution  for me at 7000 Rpm
« Last Edit: August 15, 2011, 23:50:47 pm by fredy66 » Logged
arabia slugs
« Reply #266 on: August 16, 2011, 00:23:27 am »
Smaller gen pulley turns the fan faster... but yeah, not a good idea at 7 grand Wink
fredy66
« Reply #267 on: August 16, 2011, 00:39:36 am »
stupid me   Roll Eyes
arabia slugs
« Reply #268 on: August 17, 2011, 01:07:04 am »
Is that the elusive "8" Empi filterpump you were after ?
« Reply #269 on: August 17, 2011, 01:11:38 am »
No... I've still never even seen one. I ended up using a new SLR stock grind cam (3 bolt) with an NOS EMPI gear to fit the "7" pump I already had.
