September 01, 2026, 10:50:05 am
| | |-+  Electric fuel pump
Author Topic: Electric fuel pump  (Read 8129 times)
spennyp
« on: April 17, 2007, 19:38:04 pm »
Right folks.....running a monster holley fuel pump off the ignition, so that when the ignition is on the fuel pumps , its a bit dodgy if i crash the car (heaven forbid) because if the ignition is still on the fuel will still be pumping to the carbs and believe me it pumps at a rate of knots with the large fuel pipe i have
so i need to sort this out, someone has mentioned fitting a relay and someone mentioned fitting an inertia box or a crash box which would stop the fuel pumping.
question is what do you recommend??? and how??
Java Green 64 looker....2387cc
48IDA-KDP
« Reply #1 on: April 17, 2007, 22:55:12 pm »
You could use this one from CSP
Electric  /  Switches and Relais < back
Safety cut-out relay for electric fuel pumps
With the safety-cut-out, the electric fuel pump is switched off when, e.g. in the event of an accident, the engine stops and the ignition remains switched on.
This device also protects the fuel pump against damage (risk of overheating), which can occur when the engine stops, but the ignition is on.
Comes with relais plus socket, universal wiring harness and detailed assembly instructions.
each Item/Order number Price
  Safety-cut-out relays
127 025 000R 64.00 EUR/each
(all above prices incl. german sales tax, plus shipping)
